Max speed in each gear
Old Jan 24, 2004 | 11:47 AM
sKOOTeR WRX's Avatar
Car Info: WR Blue WRX
What are the max speeds in each gear @7000 with the stock tires.
I have gone through and done calculations on what the speeds should be but I am off by a few mph in each gear.
I have an 03 WRX w/5MT
-skooter
Old Jan 24, 2004 | 11:57 AM
WRX Rush's Avatar
Car Info: Stage 4+ Bugeye
1st = 38
2nd = 71
3rd = 112 . . . . Thats what the manual says, I have expierienced
1st = 35
2nd = 68
3rd = 98 . . . thats just cause I might not take it to redline. Cheers
WRX Rush
Old Jan 24, 2004 | 02:01 PM
Do you have an automatic or a manual trans..?
Because the tops I experience are
1st... about 33
2nd...about 62
3rd... 94
4th... 127ish
Old Jan 25, 2004 | 10:07 AM
The Mirror's Avatar
I did these calculations using a tire size of 225/45VR17, which has a tire diameter of exactly 25 inches. The stock tires have a diameter of 24.9 inches, which equates to .4% smaller. Not much difference. Treadwear differences amount to as much or more.
Thus, the speeds listed in the thread are very very close.
-Mirror
https://www.i-club.com/forums/showth...speed+in+gears
Also, don't count on your factory speedo unless you've had it calibrated. They can be shockingly inaccurate.
Old Jan 25, 2004 | 09:32 PM
Mirror I have been running my car with my friends gtech meter testing the quarter mile and every time I can't hit any higher than 95mph in 3rd.
I have tried countless times to run in 3rd without shifting and I have enven tried going even into the red on the tach. My electronic boost controller monitors speed and rpm and I still can't get any higher than 95 after calc's.
I am going to try to do the grounding mod to try and help make some of the gauges and electronics more accurate.
With the speed I am hitting in each gear after I have done calc's it seems that I have a 4.2 rear axle ratio. I am not sure what happens with the 1.1 rear ratio and if that screws with any thing as far a gearing goes. AWD is so confusing why can't it just be like a standard RWD car and have one ratio... I guess this is the price you pay for traction... Traction definatly worth it..
Old Jan 25, 2004 | 11:34 PM
Wingless Wonder's Avatar
Go to a real drag strip. Their timing system is much more accurate than even the g-tech competition pro model. It's a lot safer, too.
You can't turn higher than 95 mph through the (theoretical) traps because you don't have enough power. It isn't gearing-related. MPH trap speed does not vary with small differences in gearing or tire diameter. Those variables can affect E.T. Horsepower and a wide torque curve is what generates the big MPH numbers.
Old Jan 26, 2004 | 08:33 AM
The Mirror's Avatar
If you're running stock tires, they are just shy of half a percent smaller in diameter than the 225/45/17s. That will mean fractionally lower speed in gears. I think my calc came out to 97.77mph in third on the 225/45/17s, so a .1" reduction in tire diameter (plus a little tire wear) could easily reduce that number to 95mph in your car.
Cheers,
-Mirror
Mwizard
Feb 10, 2005 08:03 AM
SHADO
Nov 24, 2003 09:15 PM
WReXcess
Jun 21, 2003 08:31 AM
