Front Right Wheel Bearing
Old Mar 19, 2014 | 11:19 AM
DriftinSquirtle's Avatar
Car Info: 2005 WRX Wagon
I have an 05 WRX wagon that I think has the front right wheel bearing finally going. the front right has had a whine at freeway speed for a while, but no noise in town or when at full lock, until this past week.
It finally got bad enough to where the front right makes noise when the wheel is at full lock. This means I am now in need of replacing that wheel bearing (I believe), and was wondering if i should just get that one done, or if it makes more sense to get both front wheel bearings done at once. I know they are known to wear out on this car.
Also, where is the best place to get this done? I live in Dublin, Ca.
Thanks!
Old May 7, 2014 | 07:28 AM
phoneman's Avatar
Car Info: 2008 Subaru outback Limited
I don't know if you took care of this yet, but any shop that you trust to do mechanical work at a reasonable price could handle it. The dealer probably would be the most expensive, but if there is a foreign car shop in the area, that might be a reasonable alternative. I see no reason to do both bearing unless you have lots of miles on it. I had to replace my RR bearing at least 3 years ago and possibly 35or 40k miles. All the others have been fine. It is probably not any cheaper to do them at the same time, because they are not duplicating any work operations.
bmxhotsauce
Jun 10, 2015 06:59 PM
H_wells3000
Jul 21, 2014 10:04 AM
THESLEEPER
Apr 3, 2010 12:32 AM
Patrick Olsen
Sep 7, 2005 06:49 PM
