Exedy clutch/flywheel install problem, help!
Old May 17, 2004 | 11:18 PM
Rocket Man's Avatar
Car Info: it's nice
the transmission place f-ed you over. Sorry to say. I had this problem and I contacted Dakin/Exedy. The first thing they asked was this a certified Exedy installer (never knew of such a thing). If you check their website out, a slight bit of error will offset what looked simple.
A sure sign was the delay of installation. it should of been a day, max.
Old May 17, 2004 | 11:36 PM
go go go's Avatar
Car Info: GF8 ver6
what kind of lightened flywheel? is it compatible with exedy clutch?
maybe the problem is there.
or they might have put the disc in inside out
gruppe-s
Apr 6, 2006 07:08 PM
gruppe-s
Engine and Drivetrain
Apr 6, 2006 07:07 PM
RavSpec
Mar 17, 2006 08:00 PM
ILP Performance
Vendor Group Buys/Specials
Dec 16, 2002 09:40 AM
