Check Engine code 420?
Old Jun 15, 2005 | 09:36 AM
SedonaSteve22's Avatar
Question Check Engine code 420?
I was on a road trip the over the weekend, when half way into the trip my "check engine" light flipped on. So at my first opportunity I stopped by a Schucks Auto Supply to use their device to hook up to my cars computer. The error code that came back was "420" which, after I got the print out, I found out it deals with the catalytic converter. Seems like my catalytic converter is working fine though, no rotten egg smell. My dad thinks it might be a bad oxygen or solenoid sensor. Just wanted to hear other peoples input if you have experienced this. I am open to any and all advice... Thanks!
Old Jun 22, 2005 | 06:10 PM
poormansporsche's Avatar
Car Info: 2.5RS STI swapped
Dude 420 man!! It's cat converter ineffiecency. Usually when you have an upgraded exhaust. When I put my Borla header on it tripped on me. Also common if you have a TBE on a WRX if i'm not mistaken. You should search it's covered everywhere.
cheers
garrett
Speed Element
Apr 20, 2006 08:41 PM
I3eXa
Jul 26, 2005 03:17 AM
Arrkash
Apr 8, 2005 10:56 AM
wonton2049
Mar 31, 2004 10:11 AM
galeth
Jun 27, 2003 05:17 PM
