What do I need to build and engine?
Old Apr 28, 2004 | 01:02 AM
ac64drew's Avatar
I've been seeing a lot of STI shortblocks for sale around $1,300-up nowadays...I wouldn't mind building an engine up for my 02 wrx(possibly 2.0 to 2.5 or 2.2) but I don't really know what components and parts I need in order to make this work?
I appreciate any suggestions that would help, thanks!!
Old Apr 29, 2004 | 02:15 PM
estrada42's Avatar
Car Info: 2002 Impreza WRX Sedan
Ask the seller what it comes with, but most shortblocks are just that blocks. Blocks with crankshafts, pistons and connecting rods, and all the internal bearings that go with it. You usually need heads with everything that goes along with them, intake and exhaust mainfolds, and all the small stuff that goes on the engine (water pump, iginition components, etc.). Again, check with the seller to make sure exactly what parts you need.
Old Apr 29, 2004 | 08:23 PM
scoobylvr's Avatar
Car Info: 1998 Impreza L EJ22
I don't know if these people are any good to deal with, but
www.nippon-motors.com
has some really good deals on wrx engines, especially the TT
Old May 1, 2004 | 03:46 PM
ac64drew's Avatar
bump
Old May 3, 2004 | 12:18 PM
ac64drew's Avatar
Wow there is absolutely nobody that has knowledge in this topic?
(...maybe there's not enough people in this section)
Old May 14, 2004 | 04:43 PM
ac64drew's Avatar
how does it hold up with just the shortblock, gasket kt and etc...? Do I have to use some parts from my 02 engine to make this work because I thought that there are other parts that are needed like pistons/rods/etc...Thanks for the info!!
Andrew
Old May 15, 2004 | 04:44 AM
go go go's Avatar
Car Info: GF8 ver6
so EJ257 short block swap will keep the compresion about the same?
Old May 15, 2004 | 08:51 PM
Kay95's Avatar
just means you can run little higher boost too
Old May 23, 2004 | 01:06 PM
danhtao's Avatar
how about putting a sti shortblock into a 2.5 rs?
the idea hit me a few nights ago, and then eventually adding a turbo kit to that
Old May 23, 2004 | 03:06 PM
Kay95's Avatar
that would be alot of work to bring a RS up to STI power handling and braking
a RS even a 98 is still over 9k-10k so if you want to do that just buy a old L with no power options and start from there
DickWRX
Jan 4, 2007 06:33 AM
STINGR
Apr 17, 2006 03:20 PM
wonton2049
Jun 27, 2005 06:50 AM
turbofreak
24
Feb 3, 2003 11:17 AM
