rear sti brake conversion
Old Aug 8, 2005 | 05:35 PM
Jizzo_02SubiWRX's Avatar
Car Info: 07SubiWRX
Exclamation rear sti brake conversion
i am thinking about converting my brakes from my wrx to the sti brake system. the front is direct bolt on. but the back might not be, does anyone know if you have to just replace the axels or just the hubs, ect. to do this swap? or, are the direct bolt on like the front.
thanks
Old Sep 1, 2005 | 04:47 PM
Vicore_Wrx's Avatar
Car Info: 2003 WRX, blue
well this is just a guess but here it goes: I think you need the hub to mount the rotor and caliper and if that is the you will probally need an axle mod to get it to fit on. or just a mod to the wrx hub like a bracket or somthing do a search I am sure this not the first time this has been asked. additionally, I also question the parking brake ability to hook up to all this modified stuff. To tell you the truth I would just get an after market kit made to work on the wrx
Old Sep 4, 2005 | 02:38 PM
Kaos22B's Avatar
thanks
you either need an adapter bracket for the brembos to mount to your stock rear hubs, or you need to change the hubs/axles/rear diff out as well (make sure to keep the right FD)
the ebrake works fine btw.
Old Sep 26, 2005 | 11:20 AM
pcowan's Avatar
Car Info: '04 STi - RallyX beast
I've actually done a conversion the other way *from* brembos on the STi. Swapping the rears is a big deal including hubs and so on. Your best bet might be to go with a WRX rear upgrade kit (stoptek, brembo, willwood, etc) which will put a larger rear disc over the existing ebrake assembly. You could also use the Subaru 2-pot rears that will swap over with no problems. Brembo also make a rear that will fit perfectly that's not the STi brembo.
Old Sep 27, 2005 | 06:41 PM
Car Info: 07SubiWRX
the reason i wanted to know if you could do it was, i can get the rear set up, calpiers, rotors, an bradied lines for 500.00 i think its a lot cheaper than buying a kit. thanks for the update
RelaxTampax
Hawaii Classifieds
Apr 11, 2013 03:29 AM
Vivalapat243
Jul 17, 2012 10:41 AM
Andrew
Oct 23, 2005 12:38 PM
Andrew
Oct 23, 2005 12:31 PM
PaulL
Apr 5, 2004 04:17 PM
