EJ20TT swap, into 914 porsche, need info about engine
Hi im currently working on a project, of putting in a Japanese Spec EJ20TT engine into a 914 Porche, what i need to know is what car the engine originally came in, what type of performance parts are availible,and any other helpful info. Also if any one has, or knows where i could get a wiring diagram for the computer and engine harness. Any info would be helpful, because this is my first venture with a Subaru, but I think it will be a neat car since the 914 weights only about 2000 pounds and the TT engine supposedly produces 325 horsepower (280 rated, but i heard it is more like 325).
The Twin turbo EJ20s all come from Legacys I believe. I think the HP has been over stated, but getting there isn't hard.
Where R U gonna put the radiator? Where is the intercoler going to be placed? holy god, what a project!!!
The radiator is going to mounted in front, angled back where the spare tire is going to be. And for the intercooler, which is the only thing i have a clearance issue with, I think im going to go with a spearco Air/Water, and mount it in the trunk area. The engine is already sitting in the car all i need know is my adapters from, kennedy which are 2-3 weeks out on orders. It is suprisingly going together with much ease.
Is/was it a 914-4 or 914-6? The 6s had larger brakes and better handleing.. I think you diffently need less body roll and better brakes.
Putting a scoop just over the roof going down against the rear window, into the engine compartment, to blow on the intercooler would look cool.. I think mounting the intercooler in the rear trunk would be too far back. You could make the verticle part out of Lexan so you could see through it. |
Why would mounting it in the rear be too far back, weight distribution concerns?
put a new sti motor in it. they are cheap, but i cannot state the price just yet. the 2.5 liters will do a 2000 lbs car good.
I already have the engine so im not gonna buy a STi engine, The car is a 914/4, I would not want to go and do this swap to a 914/6 due to the rarity and price of one. But i am going to upgrade the suspension and brakes. And the suspension and brakes are the same from the 911, so A friend of mine has a nice set of brembo's for me:D .
I would try to make the intake runner as short as possible to reduce turbo lag. Remember the longer it is, the more volume it holds , thus the turbo has to pump more air into it to pressureize it and that takes time = lag
Im doing the same thing but with a ej22t closed deck built engine.
this is a mid engine car for those who dont know. the most practical intercooler would be a water to air since there is no way youre gonna pipe the intercooler all the way to the front:eek: the latest issue of exellence has a 914 with a hole cut in the trunk and an air to air intercooler poping out of it:p . -Jose |
I would put the intercooler right in the engine cover, the black vented cover to access the engine. And I would duct some air to it either from over the roof or from around the sides of the car to the intercoolers location.
intercooler placement in 914
I am in the process of doing a swap in a bug convertable. As for the intercooler, Spal make a sweet little 7.5" fan and a pair will fit nicely on the cooler in a pull or push setup. They can be mounted directly on the front trim piece of the stock intercooler. Be careful of the screw length.
[quote][size=1][color=gray][i]Origami posted by [b]cogwheel1[/b][/i][/color]
[font=Arial][color=royalblue]I am in the process of doing a swap in a bug convertable. As for the intercooler, Spal make a sweet little 7.5" fan and a pair will fit nicely on the cooler in a pull or push setup. They can be mounted directly on the front trim piece of the stock intercooler. Be careful of the screw length. [/color][/font][/size][/quote]Thanks for the info on the electric fan. I want to mention that the person who originally posted this thread hasn't logged back onto the board since late May of 2003. [size=1][color=skyblue]-- 0==[color=blue]WW[/color]==0 "…axles of evil…" - george w. bush[/color][/size] |
help with ej25 about turbo's
is it possible to take a twin turbo kit from an ej20tt and put it on an ej25?
[QUOTE=kompleks]is it possible to take a twin turbo kit from an ej20tt and put it on an ej25?[/QUOTE]
Yep, Sandrail guys do it all the time. I just purchased an EJ20TT, and I have to do a single turbo, injector/fuel rails, headers,T3/T4, and Motec Engine management swap do to the fitment in my bug (rear engined, the secondary turbo interferes with my starter on the porsche 6 speed G50). If you are interested in putting this on your stock EJ25, leave the boost at stock level due to the higher compression. It's been done. I was just about to put everything except for the longblock up on ebay, but if you are interested, let me know. Everything would be included, vacuum lines, intake/exhaust manifolds, injectors, fuel rails...everything. Let me know your price and if it's right, it'll be on your doorstep in a couple days. |
| All times are GMT -7. The time now is 01:34 AM. |
