Need help on an OEM part's #
Old Mar 16, 2007 | 08:49 PM
SG5's Avatar
SG5
Car Info: www.hellaflush.com
Lightbulb Need help on an OEM part's #
I need help on finding that rubber piece that's been squared off. Long story short, mine has a puncture, and it's leaking brake fluid...
Matt
Old Mar 16, 2007 | 10:58 PM
Roo's Avatar
Roo
Forester Specialist
Car Info: '98/'04 Foresters (S & XT)
Matt
That piece is your lower ball joint. It is sold strictly as a complete unit, and the boot is NOT replaceable separately. It has no brake fluid to leak, however it is a sealed lubricant that might be leaking out if it is damaged.
IIRC, the part number you are looking for is 21067GA050.
Old Mar 16, 2007 | 11:02 PM
Roo's Avatar
Roo
Forester Specialist
BTW, Albany Subaru has two of them in stock, as do I...as well as the Subaru dealership in Oakland (1), and Ron Price in South San Francisco, also checking in with one in stock.
Old Mar 16, 2007 | 11:18 PM
Unit 91's Avatar
i-Club Sympathizer
I have none in stock because my dealer is n00by. Fact.
Old Mar 17, 2007 | 12:47 AM
SG5's Avatar
SG5
You know how much that would run me? That's strange, because I'm loosing brake fluid, and it's because of that puncture on that rubber piece...My brake light would light up, and when I check my brake fluid it would be low.
Old Mar 17, 2007 | 12:49 AM
Unit 91's Avatar
i-Club Sympathizer
Something else has to be going on if you're losing break fluid. Check the booster and master cylinder.
Describe the symptoms a bit more and maybe we can help better.
Roo can probably tell you list, but every dealer is free to set their own price.
Old Mar 17, 2007 | 12:53 AM
Unit 91's Avatar
i-Club Sympathizer
I reread your post and KNOW something else is going on. The ball joint isn't even connected to the ball joint. Something else is going on. What year/mileage is your car? I'm guessing you might have a master cylinder problem.
Old Mar 17, 2007 | 01:01 AM
SG5's Avatar
SG5
hmm, it seems like that's the only thing that's leaking though. I have an 06 with about 10k miles on it.
Old Mar 17, 2007 | 01:07 AM
Unit 91's Avatar
i-Club Sympathizer
Wow. I said the ball joint isn't connected to the ball joint. I meant connected to tbe brake system.
Give me some car info. Year, miles, etc.
I'm suspecting master cyl.
Old Mar 17, 2007 | 01:14 AM
AzN121184's Avatar
Car Info: civic
2006 impreza wrx with 4/2piston brakes.
and extra pandas.
Old Mar 17, 2007 | 01:19 AM
Unit 91's Avatar
i-Club Sympathizer
I think the Pandas might be your problem.
Hmmm... pull the booster. I bet it's filled with fluid.
Old Mar 17, 2007 | 01:23 AM
Unit 91's Avatar
i-Club Sympathizer
I'm going to sleep. I'll check in tomorrow.
Old Mar 17, 2007 | 01:28 AM
SG5's Avatar
SG5
wanna tell me how do i pull the booster? Where is the booster? lol *_*
Old Mar 17, 2007 | 01:29 AM
SG5's Avatar
SG5
and extra pandas.
Yeah it's HAS to be the pandas or your GF, MINNIE.
Old Mar 17, 2007 | 02:04 AM
Long_Travel_WRX's Avatar
Car Info: stock 04 wrx sedan
Jack up the car take the wheel off have somebody pump the brakes then hold them down while you look for a leak could be a nick in the line or banjo bolt leaking, torn piston ect
