Help please, no acceleration after shifting into 5th during hard acceleration
Old Jul 16, 2010 | 10:01 PM
subie OCD's Avatar
Car Info: 04 STi
Boost leak? I had a similar issue and found that an intercooler hose wasn't clamped all the way.
Old Jul 16, 2010 | 10:10 PM
I do not think so. It would happen in 3rd & 4th. You hit full boost there.
VV new sig just for you
Old Jul 16, 2010 | 11:07 PM
DerekB707's Avatar
Car Info: 07 rs STi swapped Rotated BW S200SX-56
I have done a leak down test and it's solid. I have been told there is a fix for this with tuning. Will post up the results after I get to test it. Thanks for the idea though.
Old Jul 16, 2010 | 11:44 PM
NorCalDC5's Avatar
Car Info: 2016 FXT
Same thing used to happen to me all the time, even when it was 20 degrees out (texas). Never figured out what it was since the motor was pulled a few weeks later for other reasons..let me know what your tuner says!
Old Jul 17, 2010 | 07:23 AM
DerekB707's Avatar
Will do, I'm going to go back to the track and run it again after the adjustment to the tune. I'll post the results of how it runs and what he did if it cures the problem.
Old Jul 17, 2010 | 07:41 AM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
The first step in proper diag is identifying the cause of the symptom/problem.
Was any work performed on the vehicle just prior to the symptom occurring?
How long has the problem been occurring?
You say it happened at T-Hill?
When was that?
Old Jul 17, 2010 | 08:51 AM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
This is the same shifting issue that has been around for a log time and is especially prevelent in the 06 ECU. It occurrs when boost stays above ~9psi between gears. The ECU responds by cutting fuel in the next gear until boost drops below the threshold. There are a couple fixes for this. Cobb's LC/FFS maps fix this issue and allow you to shift as quickly as you like without issue. Remember this only happens if the driver is shifting fast/hard enough as to not drop out of boost between gears.
Derek, I'll get you your map with LC later today to try out.
-- Ed
Old Jul 17, 2010 | 08:55 AM
DerekB707's Avatar
When was that?
June 1st was the first time I noticed it. I hadn't ran it hard since fall of last year. Since then I did a 6MT swap, went back to a TMIC, added a MBC, EL, & inlet. I had it tuned and it put down 290/321 to the wheels at 17.5-18psi. Car runs well and pulls to redline, it's just the transition into 5th gear that is giving me the fit. It is weird to me why it only happens in in the 4-5 shift. It is just as if I turned the ignition key off and then turned it back on.
Old Jul 17, 2010 | 09:03 AM
iClub Silver Vendor
Was the problem present last Fall when you ran it hard?
Obviously, with the hardware changes, it's safe to assume that the ECM calibration you were running last Fall was different than the current calibration.
Old Jul 17, 2010 | 09:42 AM
DerekB707's Avatar
-- Ed
Thank you Ed, I appreciate it!!
Yeah, major changes. I bought the car with the FMIC setup, it had another tune in it done by the previous owner at another shop somewhere. I wanted to make it easier to pass smog, so I ditched the FMIC. I also broke the 5 speed on Christmas eve last year, so I did the 6MT swap. I never noticed it before, but I don't know what the tune was setup for either, one of the joys of purchasing a used modified car.
Old Jul 17, 2010 | 11:56 AM
NorCalDC5's Avatar
Car Info: 2016 FXT
-- Ed
Wow, I wish someone told me this before! I have been dumbfounded for almost 2 years because of this!
Old Jul 17, 2010 | 12:00 PM
EQ Tuning's Avatar
iClub Silver Vendor
Car Info: A Laptop
Yep we figured this out back in 06-07 when Sean was trying to run an 11 second pass. Shortly after, we worked on solving the issue with Cobb and the open source guys. I have a fix for open source 06 STI's, but I'll have to look into the 07. Cobb's LC maps fix the issue on all ECU's.
-- Ed
Old Jul 17, 2010 | 12:14 PM
DerekB707's Avatar
That sucks, 2 years? You don't get to take full advantage of your cars power with this problem. I know it doesn't affect us in everyday driving, it just makes it where you can't use it on the track very well when this happens.
Old Jul 17, 2010 | 12:17 PM
NorCalDC5's Avatar
Car Info: 2016 FXT
Well my car has been down for 2 years so it didn't really matter But it should soon!
Old Jul 17, 2010 | 02:08 PM
boxerfxt's Avatar
Car Info: 2005 forester
-- Ed
wholy crap my car has done this for the last 2 years and I learned to drive around the issue! thanks ed .. when I have it tuned again I will add the ffs to the map! even though I dont do it because im a little girl in a big skirt and I drive a forester.
Top
