HELP!! Need rear passenger side back lateral link! VENDORS HELP TOO!
Old Apr 30, 2008 | 08:49 PM
mattsn0w's Avatar
Exclamation HELP!! Need rear passenger side back lateral link! VENDORS HELP TOO!
EDIT: mulcibre hooked an i-club brother up and even installed the part for me at my work where my car was stranded. BIG THANKS TO SAM!!! w00000TT!!!!!!!!!
Ironically my buddy Shayne broke the same damn thing 3 weeks back.
I need a rear passenger side lateral link from an 02-07 Impreza WRX wagon ASAP! Just like in the above picture.
I am in san jose off 280 & saratoga evenings/weekends and in san mateo during the day for work. I can most likely meet up within 15 minutes driving from these areas.
please, please, please, please, please, please, PLEASE! if you have one of these in your garage hook an i-club bro up!
Also, if you have WAGON spec after market lateral links please post or PM me a price and i'll likely buy them.
..Matt
Old Apr 30, 2008 | 09:19 PM
Mars_D's Avatar
Car Info: 05 Saab 92x
Sounds like you need these like, yesterday.
If you weren't in a hurry, theres some F/S here...
http://saab92x.com/viewtopic.php?id=19705
Good luck, I'm sure somewhere local will come through.
Old Apr 30, 2008 | 09:43 PM
speedykanaan's Avatar
Car Info: 02 wrx
I'm hoping to be wrong, the ones on the sedans are wider?!?!?! If they are not, then I have a whole set that would be taken off my sedan this weekend.
Old Apr 30, 2008 | 09:49 PM
darkonion's Avatar
Chicks dig me. April Fool's!
PM mulcibre. He has my L lateral links that he might sell you.
I don't know if the lateral links from sedan or wagons are different in length, but I can tell you that according to Whiteline, their rear adjustable lateral links, the KTA108 and KTA109 are different only by the rear sway bar mounting point.
I should also mention that the Whiteline KTA108 is about $275ish, more or less. Used aftermarket ones, that I've seen, sell from $200-$250 depending on condition.
Old Apr 30, 2008 | 09:52 PM
mattsn0w's Avatar
Yes, the sedan has a wider track so I would need sedan axles to use sedan lateral links.
Thanks though!
Old Apr 30, 2008 | 09:53 PM
mattsn0w's Avatar
Will these for sure fit?
Old May 1, 2008 | 08:00 AM
mattsn0w's Avatar
bump.
Old May 1, 2008 | 08:31 AM
Racenut's Avatar
Car Info: WR Blue Wagon
I could put a piece of rebar in mine and weld it back together for you
You should have broke the other side
Old May 1, 2008 | 11:13 AM
Hatteroo's Avatar
Hey Matt. Try contacting Noah over @ LIC. They have a ton of stock suspension stuff and I'm sure they may have this part.
Old May 1, 2008 | 11:15 AM
joltdudeuc's Avatar
Old School
Car Info: '99 RBP GM6
Thanks though!
Rear links should be the same. 05+ Sti have different link length. And the front is where the L Arms is probably different.
RSBs are the same wagon/sedan, and the RS links are the same at a sedan, so should be fine for any link you can snag.
Old May 1, 2008 | 11:21 AM
darkonion's Avatar
Length may be the same, but like I said in my earlier post, I think the mounting point is different. See link:
https://www.i-club.com/forums/showpo...&postcount=183
Old May 1, 2008 | 11:23 AM
joltdudeuc's Avatar
Old School
The ones off the saab will fit
Old May 1, 2008 | 11:25 AM
joltdudeuc's Avatar
Old School
That message looks like he's talking about where the sway bar mounts for those white line products.
They don't make different wagon/sedan rear sway bars right? Or am I just completely wrong?
Old May 1, 2008 | 11:30 AM
joltdudeuc's Avatar
Old School
..Matt
What the hell is up with you guys breaking these links
mulcibre's Avatar
Car Info: 1994 impreza L
I have the full set off my L, it should fit fine, and there are aftermarket bushings!
Let me know, I got them for $40 and will let the set go for the same I guess. Noltec poly bushings and all. I can meet you on-site
