Help need parts!!
Old Aug 8, 2004 | 12:56 AM
bringndefinitio's Avatar
Car Info: 03 WRX + 08 335i + 07 Tahoe Lt3
Help need parts!!
Hey guys I was wondering if you guys can help me out on a hunt for some parts. First off I need some injector o-rings and seals for a my03 wrx of course. I also need some turbo gaskets, and a bolt that is missing from my turbo stud(14mm not sure thread type). And my last question is, by missing that turbo bolt I couldve possibly had a boost leak correct?
Old Aug 8, 2004 | 09:35 PM
anybody?
Old Aug 8, 2004 | 09:40 PM
ElJefe's Avatar
Car Info: '02 Black WRX 6speed MT, 05 Evo GSR, 03 M3 SMG
I have an uppipe to turbo nut missing and I dont have any kind of leaks!
Old Aug 8, 2004 | 11:40 PM
interesting
Old Aug 9, 2004 | 12:54 AM
AzN121184's Avatar
Car Info: civic
can't u just buy the turbo bolt...from homedepot or something?
Old Aug 9, 2004 | 12:56 AM
I probably could... I wonder in terms of material will a bolt from home depot hold up with against heat from the turbo??? probably a noobie question but I am cruious
Old Aug 9, 2004 | 01:11 AM
AzN121184's Avatar
Car Info: civic
or my best advice is to go look it up @ www.subaruparts.com
Old Aug 9, 2004 | 01:12 AM
dan avoN7's Avatar
2006 Mt Hammy Car Show Winner
Car Info: Black 03 WRX, White 04 E46 M3
a bolts a bolt...... just get one of similiar size and you will be fine. If you were only missing one, the chances of a leak at that spot (turbo to downpipe) isn't very likely.
Old Aug 9, 2004 | 02:41 AM
AzN121184's Avatar
Car Info: civic
i thought some bolts are stronger than others. Anyways, that's what i was told, theres also a number on majority of the bolts that tell what it's made of and other things. maybe i'm wrong, who knows.
Old Aug 9, 2004 | 07:14 AM
ElJefe's Avatar
Maybe this will help a little more. When I bought my uppipe it came without any stud, so I went ahead and bought some bolts from OSH and I bolted them up from the turbo down to the uppipe. I didnt use any nuts, just the thread on the uppipe. I did use ONE stud from the stock uppipe, I was unable to take off the rest. That one stud that I'm using is without a nut on top, I havent had any leaks for the past half year.
Old Aug 9, 2004 | 08:39 AM
stimul8n's Avatar
a bolt is NOT a bolt. the materials are all different, how they are made, whether they are strengthened, etc. etc. NEVER think that a home depot replacement will work for something in your car unless a mechanic tells you it is...
that doesn't mean that a home depot bolt wouldn't work, it just means that it may not be strong enough, may not be able to handle the heat or vibration or soemthing, and are more prone to failure.
Old Aug 9, 2004 | 09:18 AM
ElJefe's Avatar
I agree, if I have any problems that will just give me an excuse to upgrade to something else. So far I haven't had any, luck maybe?
unstble
Mar 21, 2008 09:09 AM
mav1c
17
Jan 9, 2006 08:04 AM
Nivek-CA
Subaru OEM Parts For Sale
13
Jan 15, 2004 07:38 PM
