check engine light
check engine light
hey guys new to the forum hate to start out with a problem right away. but im gonna be that guy cause today for new years my check engine light turned on.
whats wierd is that the cruise control light is also blinking. i have an 06 wrx anyone heard of this before? just seein what i should do before i put it in the shop. Also anyone know of a good place around Vacaville? thanks for the help!
Ya I have had it happen before in my wagon. Have the code pulled but its possibly a misfire.
Do you have a lightened flywheel or after market clutch?
By the way...
Mileage and mods list?
Don't drive your car to hard, from what I was told is your car has put itself in a safe map mode so it doesn't cause other damage.
Just be easy til you get the cel pulled.
By the way...
got the scanner from code3suby and it spit out these codes
p0301 p0302 p0303 p0304 p1575
so misfire for all 4 cylinders and P1572 IMM Circuit Failure (Except Antenna Circuit
if i have the right list. anyone know the cel code list for 06???
here is a list of a bunch of codes, not seeing p1575 though
http://www.obd-codes.com/trouble_cod...obd2-codes.php
Also, whenever the Cruise control light flashes, it means your car misfired. It will flash for awhile and then eventually turn off. Most of the time this happens and it doesn't trigger the Check Engine light
LIC is your closest reputable shop, I'd suggest having the car towed there unless you're still under warranty.
LIC Motorsports
865 Sweetser Avenue
Novato, CA 94945
(415) 892-7400
Oh, and welcome to i-club
I don't think retarded is the PC term anymore.
LIC Motorsports
865 Sweetser Avenue
Novato, CA 94945
(415) 892-7400
