Aftermarket Forced Induction - Turboed factory NA engines Turbo EJ25! Who said that all Subarus are created equal? Aftermarket turbochargers on factory normally-aspirated engines (factory turbo engines have their own forums).
Old Jul 7, 2005 | 07:10 AM
Dynapar's Avatar
hey all,
i am planning to do some forced induction on my 95 impreza 2.2l. i am using a custom made kit. which will incorporate a TD04 (stock wrx turbo). the plan is to run 4psi on the stock block.
i am wondering how the stock ecu will react to some boostin. i have heard that some people have had success using the stock ecu @ 6 psi. i know that the stock ecu is very adaptable but i dont know how adapatable since i would also like to switch to larger injectors eventually.
this leads me tinto my next issue. since i want to run aftermarket engine managemene, however most the systems i have seen like a cobb ap or at, and u-techs are built for WRX/STis i dont know what i can use in my car. i have thought about the perfect power piggy back but i dont know if that wil give me the control over the enign ei need to make it run correctly. also i have heard OF the hydra system but i know nothing about it.
so basically what should i do for my engine managemnet for my forced induction stock car. (95 impreza lx 2.2l AWD Auto)
Old May 1, 2007 | 11:54 AM
Baker's Avatar
Car Info: 1996 impreza 2.2L
Safc-2
Old May 4, 2007 | 10:24 PM
cbf246's Avatar
Car Info: 04 WRX
for something as big as this, id consider contacting all the vendors on the forum to find out all your options. if you wanna go full stand-alone, you may end up splicing your wiring harness, but youll have to check.
Imprezer
Jan 23, 2003 05:00 AM
odyss3y
Nov 26, 2002 01:32 PM
stealth-wrx
Wanted
Nov 22, 2002 11:30 AM
i-speed
Nov 22, 2002 04:34 AM
