93-95 Impreza Front Wheel Drive (FWD) Parts
Car Info: 1995 Coupe, Sedan, Wagon & 2009 FXT
These are from my personal builds over the last 10 years.
I listed each item from the year of the car it from. Some of these will fit 1993-2001. If unsure, please ask! I will do my best to answer.
I will gladly combine prices on parts; please send me your offers as well!
- Chris
Located: Torrance, CA 90503
All shipped prices include PayPal fees!
Parts:
1995 Base FWD Front Exhaust Heat Shield & Bolts - $10 + Shipping
1995 Base FWD Middle Exhaust Heat Shield & Bolts - $10 + Shipping
1995 Sedan FWD Middle Exhaust Heat Shield - $10 + Shipping
1995 L Coupe Rear Sub-frame with Bolts - $20 + Shipping
1995 L Sedan Rear Sub-frame with Bolts - $20 + Shipping
1995 L Coupe Drum Rotors / Rear Hubs - $20 + Shipping
1995 Base Drum Rotors / Rear Hubs - $20 + Shipping
1995 L Sedan Drum Rotors / Rear Hubs - $20 + Shipping
1995 L Coupe Rear Lateral Link Tow Bolts - $15 Shipped
1995 L Sedan Rear Lateral Link Tow Bolts - $15 Shipped
1995 Base Coupe Rear Lateral Link Tow Bolts - $15 Shipped
1995 L No ABS Rear Drum Rear Brake Proportioning Valve / Brake Pressure Valve - $15 Shipped
1995 Base FWD Gas Tank (Complete w/ Straps) - $20 Picked Up
1995 FWD Manual Transmission [Disassembled] (See Section for Breakdown)
Pictures:
1995 L Drum Rotors / Rear Hubs - $20 + Shipping
Worked fine when pulled for an AWD swap.
Rear Drum Brake Lines [26531AA020]
Pulled at 130K
The transmission needed a rebuild; the main shaft bearing is toast, and the gears are showing wear from it. The front differential is still in great shape per AQ. I disassembled the transmission and will ship everything.
Parts:
- Stickers
- Cases - $20 Each Side + Shipping
- Rear End Section / Cap - SOLD
- Front Differential - $60 Shipped
- Shifter Arm & Joint - $30 Shipped
- 1st-2nd Shift Rod & Fork - $20 Shipped
- 3rd-4th Shift Rod & Fork - $20 Shipped
- Reverse Shifter Lever, Idler Gear (One Tooth Partially Chipped) & Shaft - $15 Shipped
- Main Shaft – $30 Shipped
- Drive Pinion Shaft - $40 Shipped (Due to Weight)
- Pitching Stopper Bracket & Release Fork Return Spring Bracket - $15 Shipped
- Release Fork Cable Bracket - $10 Shipped
- Release Fork - $25 Shipped
- Neutral & Back-Up Light Switches - $15 Shipped Each
Stickers
- Chris
Parts:
Pictures:
Pulled at 130K
Parts:
- Stickers
Stickers
- Chris
Parts:
Pictures:
Pulled at 130K
Parts:
- Stickers
Stickers
- Chris
Parts:
Pictures:
Pulled at 130K
Parts:
- Stickers
Stickers
