93-95 Impreza Front Wheel Drive (FWD) Parts
These are from my personal builds over the last 10 years.
I listed each item from the year of the car it from. Some of these will fit 1993-2001. If unsure, please ask! I will do my best to answer. I will gladly combine prices on parts; please send me your offers as well! - Chris [B] Located: [/B] Torrance, CA 90503 [B] All shipped prices include PayPal fees! [/B] [B][SIZE=3][COLOR=Red] Parts: [/COLOR][/SIZE][/B] 1995 Base FWD Front Exhaust Heat Shield & Bolts - $10 + Shipping 1995 Base FWD Middle Exhaust Heat Shield & Bolts - $10 + Shipping 1995 Sedan FWD Middle Exhaust Heat Shield - $10 + Shipping 1995 L Coupe Rear Sub-frame with Bolts - $20 + Shipping 1995 L Sedan Rear Sub-frame with Bolts - $20 + Shipping 1995 L Coupe Drum Rotors / Rear Hubs - $20 + Shipping 1995 Base Drum Rotors / Rear Hubs - $20 + Shipping 1995 L Sedan Drum Rotors / Rear Hubs - $20 + Shipping 1995 L Coupe Rear Lateral Link Tow Bolts - $15 Shipped 1995 L Sedan Rear Lateral Link Tow Bolts - $15 Shipped 1995 Base Coupe Rear Lateral Link Tow Bolts - $15 Shipped 1995 L No ABS Rear Drum Rear Brake Proportioning Valve / Brake Pressure Valve - $15 Shipped 1995 Base FWD Gas Tank (Complete w/ Straps) - $20 Picked Up 1995 FWD Manual Transmission [Disassembled] (See Section for Breakdown) [B][SIZE=3][COLOR=Green] Pictures: [/COLOR][/SIZE][/B] 1995 Base FWD Front Exhaust Heat Shield & Bolts - $10 + Shipping [img]https://farm5.staticflickr.com/4540/24106775377_a02d5a9be2_k.jpg[/img] [img]https://farm5.staticflickr.com/4535/38255565274_3f8c9b8181_k.jpg[/img] 1995 Base FWD Middle Exhaust Heat Shield & Bolts - $10 + Shipping [img]https://farm5.staticflickr.com/4527/38255563984_6dd1ae99f3_k.jpg[/img] [img]https://farm5.staticflickr.com/4589/38255563524_ca633e50d4_k.jpg[/img] 1995 Sedan FWD Middle Exhaust Heat Shield - $10 + Shipping [img]https://farm2.staticflickr.com/1894/30639338628_8337fedd14_k.jpg[/img] [img]https://farm2.staticflickr.com/1874/30639340038_575d48a0ed_k.jpg[/img] 1995 L Coupe Rear Sub-frame with Bolts - $20 + Shipping [img]https://farm5.staticflickr.com/4295/36057196091_0985d3b888_k.jpg[/img] [img]https://farm5.staticflickr.com/4330/35386486433_5d4631773f_k.jpg[/img] [img]https://farm5.staticflickr.com/4423/36908373026_b7a855dda1_k.jpg[/img] 1995 L Sedan Rear Sub-frame with Bolts - $20 + Shipping [img]https://c1.staticflickr.com/5/4261/35094266231_4a4da0c196_k.jpg[/img] [img]https://c1.staticflickr.com/5/4263/35058522152_85f6b07f69_k.jpg[/img] [img]https://farm5.staticflickr.com/4349/36908373446_a8a6a9e3fb_k.jpg[/img] 1995 L Drum Rotors / Rear Hubs - $20 + Shipping Worked fine when pulled for an AWD swap. [img]https://farm5.staticflickr.com/4315/36148081216_808d2106be_k.jpg[/img] [img]https://farm5.staticflickr.com/4301/36148081716_9f7b8c3db9_k.jpg[/img] [img]https://farm5.staticflickr.com/4308/35798600860_99b42aa2a5_k.jpg[/img] [img]https://farm5.staticflickr.com/4292/36148080616_ad913e15b6_k.jpg[/img] 1995 Base Drum Rotors / Rear Hubs - $20 + Shipping Worked fine when pulled for an AWD swap. [img]https://farm5.staticflickr.com/4293/36148078506_fbb32e0c76_k.jpg[/img] [img]https://farm5.staticflickr.com/4297/36148079086_0ce7d57b80_k.jpg[/img] [img]https://farm5.staticflickr.com/4295/36055681241_b34a04b0e5_k.jpg[/img] [img]https://farm5.staticflickr.com/4304/36055681931_d80d789863_k.jpg[/img] Rear Drum Brake Lines [26531AA020] [img]https://farm5.staticflickr.com/4320/35386486803_516767338d_k.jpg[/img] 1995 L Sedan Drum Rotors / Rear Hubs - $20 + Shipping Worked fine when pulled for an AWD swap. [img]https://farm5.staticflickr.com/4498/37506470736_c837b17d50_k.jpg[/img] [img]https://farm5.staticflickr.com/4497/37506471186_655ddf558b_k.jpg[/img] [img]https://farm5.staticflickr.com/4505/37506471526_6e5ab3b4da_k.jpg[/img] 1995 L Coupe Rear Lateral Link Tow Bolts - $15 Shipped [img]https://farm5.staticflickr.com/4654/39114106684_f89906d38c_k.jpg[/img] 1995 L Sedan Rear Lateral Link Tow Bolts - $15 Shipped [img]https://farm5.staticflickr.com/4766/39114105424_31c6fbb7cb_k.jpg[/img] 1995 Base Coupe Rear Lateral Link Tow Bolts - $15 Shipped [img]https://farm5.staticflickr.com/4764/25950765438_eda58602c3_k.jpg[/img] 1995 L No ABS Rear Drum Rear Brake Proportioning Valve / Brake Pressure Valve - $15 Shipped [img]https://farm4.staticflickr.com/3679/33435167081_816fa57e80_z.jpg[/img] 1995 Base FWD Gas Tank (Complete w/ Straps) - $20 Picked Up [img]https://live.staticflickr.com/8684/28159796370_e2c359577b_z.jpg[/img] [img]https://live.staticflickr.com/8733/28159795180_8658b2ddc1_z.jpg[/img] [img]https://live.staticflickr.com/8712/28159795910_d56a7b2bb6_z.jpg[/img] [img]https://live.staticflickr.com/4203/34589355693_17d042c263_z.jpg[/img] [img]https://live.staticflickr.com/4224/35398548475_aced6e9d10_z.jpg[/img] [img]https://live.staticflickr.com/4229/35398548825_8c4462583b_z.jpg[/img] [img]https://live.staticflickr.com/65535/48071031803_c700756849_k.jpg[/img] 1995 FWD Manual Transmission [Disassembled] Pulled at 130K The transmission needed a rebuild; the main shaft bearing is toast, and the gears are showing wear from it. The front differential is still in great shape per AQ. I disassembled the transmission and will ship everything. Parts: - Stickers - Cases - $20 Each Side + Shipping - Rear End Section / Cap - SOLD - Front Differential - $60 Shipped - Shifter Arm & Joint - $30 Shipped - 1st-2nd Shift Rod & Fork - $20 Shipped - 3rd-4th Shift Rod & Fork - $20 Shipped - Reverse Shifter Lever, Idler Gear (One Tooth Partially Chipped) & Shaft - $15 Shipped - Main Shaft – $30 Shipped - Drive Pinion Shaft - $40 Shipped (Due to Weight) - Pitching Stopper Bracket & Release Fork Return Spring Bracket - $15 Shipped - Release Fork Cable Bracket - $10 Shipped - Release Fork - $25 Shipped - Neutral & Back-Up Light Switches - $15 Shipped Each Stickers [img]https://farm5.staticflickr.com/4330/36054755261_22d54da14b_k.jpg[/img] Cases - $20 Each Side + Shipping [img]https://farm5.staticflickr.com/4323/35352216934_62fc0d0195_k.jpg[/img] [img]https://farm5.staticflickr.com/4317/36054830501_f992ae39a1_k.jpg[/img] [img]https://farm5.staticflickr.com/4308/36187982115_858549efdd_k.jpg[/img] [img]https://farm5.staticflickr.com/4299/35352204304_d8abe32752_k.jpg[/img] [img]https://farm5.staticflickr.com/4326/36054830181_fdf2e9ed64_k.jpg[/img] [img]https://farm5.staticflickr.com/4292/36020454952_5fcaac7a45_k.jpg[/img] [img]https://farm5.staticflickr.com/4316/35352206594_6d14c3c8e4_k.jpg[/img] Front Differential - $60 Shipped [img]https://farm5.staticflickr.com/4303/36054829411_206c85df6d_k.jpg[/img] Shifter Arm & Joint - $30 Shipped [img]https://farm5.staticflickr.com/4298/36147034926_96fb3d183e_k.jpg[/img] 1st-2nd Shift Rod & Fork - $20 Shipped [img]https://farm5.staticflickr.com/4310/36187983125_8c10618920_k.jpg[/img] 3rd-4th Shift Rod & Fork - $20 Shipped [img]https://farm5.staticflickr.com/4309/35352207704_d45884e661_k.jpg[/img] Reverse Shifter Lever, Idler Gear (One Tooth Partially Chipped) & Shaft - $15 Shipped [img]https://farm5.staticflickr.com/4291/36147034396_85ce99d2c9_k.jpg[/img] Main Shaft – $30 Shipped [img]https://farm5.staticflickr.com/4319/35352218564_4e3be49204_k.jpg[/img] Drive Pinion Shaft - $40 Shipped (Due to Weight) [img]https://farm5.staticflickr.com/4311/36054829201_e1c2e8ce35_k.jpg[/img] Pitching Stopper Bracket & Release Fork Return Spring Bracket - $15 Shipped [img]https://farm5.staticflickr.com/4307/35352202874_65a4e88529_k.jpg[/img] Release Fork Cable Bracket - $10 Shipped [img]https://farm5.staticflickr.com/4328/36187981105_48959ac9c9_k.jpg[/img] Release Fork - $25 Shipped [img]https://farm5.staticflickr.com/4300/36054829611_50fd1f7a38_k.jpg[/img] Neutral & Back-Up Light Switches - $15 Shipped Each [img]https://farm5.staticflickr.com/4319/36020463912_1e78587996_k.jpg[/img] These are from my personal builds over the last 10 years. I listed each item from the year of the car it from. Some of these will fit 1993-2001. If unsure, please ask! I will do my best to answer. I will gladly combine prices on parts; please send me your offers as well! - Chris [B] Located: [/B] Torrance, CA 90503 [B] All shipped prices include PayPal fees! [/B] [B][SIZE=3][COLOR=Red] Parts: [/COLOR][/SIZE][/B] 1995 Base FWD Front Exhaust Heat Shield & Bolts - $10 + Shipping 1995 Base FWD Middle Exhaust Heat Shield & Bolts - $10 + Shipping 1995 Sedan FWD Middle Exhaust Heat Shield - $10 + Shipping 1995 L Coupe Rear Sub-frame with Bolts - $20 + Shipping 1995 L Sedan Rear Sub-frame with Bolts - $20 + Shipping 1995 L Coupe Drum Rotors / Rear Hubs - $20 + Shipping 1995 Base Drum Rotors / Rear Hubs - $20 + Shipping 1995 L Sedan Drum Rotors / Rear Hubs - $20 + Shipping 1995 L Coupe Rear Lateral Link Tow Bolts - $15 Shipped 1995 L Sedan Rear Lateral Link Tow Bolts - $15 Shipped 1995 Base Coupe Rear Lateral Link Tow Bolts - $15 Shipped 1995 L No ABS Rear Drum Rear Brake Proportioning Valve / Brake Pressure Valve - $15 Shipped 1995 Base FWD Gas Tank (Complete w/ Straps) - $20 Picked Up 1995 FWD Manual Transmission [Disassembled] (See Section for Breakdown) [B][SIZE=3][COLOR=Green] Pictures: [/COLOR][/SIZE][/B] 1995 Base FWD Front Exhaust Heat Shield & Bolts - $10 + Shipping [img]https://farm5.staticflickr.com/4540/24106775377_a02d5a9be2_k.jpg[/img] [img]https://farm5.staticflickr.com/4535/38255565274_3f8c9b8181_k.jpg[/img] 1995 Base FWD Middle Exhaust Heat Shield & Bolts - $10 + Shipping [img]https://farm5.staticflickr.com/4527/38255563984_6dd1ae99f3_k.jpg[/img] [img]https://farm5.staticflickr.com/4589/38255563524_ca633e50d4_k.jpg[/img] 1995 Sedan FWD Middle Exhaust Heat Shield - $10 + Shipping [img]https://farm2.staticflickr.com/1894/30639338628_8337fedd14_k.jpg[/img] [img]https://farm2.staticflickr.com/1874/30639340038_575d48a0ed_k.jpg[/img] 1995 L Coupe Rear Sub-frame with Bolts - $20 + Shipping [img]https://farm5.staticflickr.com/4295/36057196091_0985d3b888_k.jpg[/img] [img]https://farm5.staticflickr.com/4330/35386486433_5d4631773f_k.jpg[/img] [img]https://farm5.staticflickr.com/4423/36908373026_b7a855dda1_k.jpg[/img] 1995 L Sedan Rear Sub-frame with Bolts - $20 + Shipping [img]https://c1.staticflickr.com/5/4261/35094266231_4a4da0c196_k.jpg[/img] [img]https://c1.staticflickr.com/5/4263/35058522152_85f6b07f69_k.jpg[/img] [img]https://farm5.staticflickr.com/4349/36908373446_a8a6a9e3fb_k.jpg[/img] 1995 L Drum Rotors / Rear Hubs - $20 + Shipping Worked fine when pulled for an AWD swap. [img]https://farm5.staticflickr.com/4315/36148081216_808d2106be_k.jpg[/img] [img]https://farm5.staticflickr.com/4301/36148081716_9f7b8c3db9_k.jpg[/img] [img]https://farm5.staticflickr.com/4308/35798600860_99b42aa2a5_k.jpg[/img] [img]https://farm5.staticflickr.com/4292/36148080616_ad913e15b6_k.jpg[/img] 1995 Base Drum Rotors / Rear Hubs - $20 + Shipping Worked fine when pulled for an AWD swap. [img]https://farm5.staticflickr.com/4293/36148078506_fbb32e0c76_k.jpg[/img] [img]https://farm5.staticflickr.com/4297/36148079086_0ce7d57b80_k.jpg[/img] [img]https://farm5.staticflickr.com/4295/36055681241_b34a04b0e5_k.jpg[/img] [img]https://farm5.staticflickr.com/4304/36055681931_d80d789863_k.jpg[/img] Rear Drum Brake Lines [26531AA020] [img]https://farm5.staticflickr.com/4320/35386486803_516767338d_k.jpg[/img] 1995 L Sedan Drum Rotors / Rear Hubs - $20 + Shipping Worked fine when pulled for an AWD swap. [img]https://farm5.staticflickr.com/4498/37506470736_c837b17d50_k.jpg[/img] [img]https://farm5.staticflickr.com/4497/37506471186_655ddf558b_k.jpg[/img] [img]https://farm5.staticflickr.com/4505/37506471526_6e5ab3b4da_k.jpg[/img] 1995 L Coupe Rear Lateral Link Tow Bolts - $15 Shipped [img]https://farm5.staticflickr.com/4654/39114106684_f89906d38c_k.jpg[/img] 1995 L Sedan Rear Lateral Link Tow Bolts - $15 Shipped [img]https://farm5.staticflickr.com/4766/39114105424_31c6fbb7cb_k.jpg[/img] 1995 Base Coupe Rear Lateral Link Tow Bolts - $15 Shipped [img]https://farm5.staticflickr.com/4764/25950765438_eda58602c3_k.jpg[/img] 1995 L No ABS Rear Drum Rear Brake Proportioning Valve / Brake Pressure Valve - $15 Shipped [img]https://farm4.staticflickr.com/3679/33435167081_816fa57e80_z.jpg[/img] 1995 Base FWD Gas Tank (Complete w/ Straps) - $20 Picked Up [img]https://live.staticflickr.com/8684/28159796370_e2c359577b_z.jpg[/img] [img]https://live.staticflickr.com/8733/28159795180_8658b2ddc1_z.jpg[/img] [img]https://live.staticflickr.com/8712/28159795910_d56a7b2bb6_z.jpg[/img] [img]https://live.staticflickr.com/4203/34589355693_17d042c263_z.jpg[/img] [img]https://live.staticflickr.com/4224/35398548475_aced6e9d10_z.jpg[/img] [img]https://live.staticflickr.com/4229/35398548825_8c4462583b_z.jpg[/img] [img]https://live.staticflickr.com/65535/48071031803_c700756849_k.jpg[/img] 1995 FWD Manual Transmission [Disassembled] Pulled at 130K The transmission needed a rebuild; the main shaft bearing is toast, and the gears are showing wear from it. The front differential is still in great shape per AQ. I disassembled the transmission and will ship everything. Parts: - Stickers - Cases - $20 Each Side + Shipping - Rear End Section / Cap - SOLD - Front Differential - $60 Shipped - Shifter Arm & Joint - $30 Shipped - 1st-2nd Shift Rod & Fork - $20 Shipped - 3rd-4th Shift Rod & Fork - $20 Shipped - Reverse Shifter Lever, Idler Gear (One Tooth Partially Chipped) & Shaft - $15 Shipped - Main Shaft – $30 Shipped - Drive Pinion Shaft - $40 Shipped (Due to Weight) - Pitching Stopper Bracket & Release Fork Return Spring Bracket - $15 Shipped - Release Fork Cable Bracket - $10 Shipped - Release Fork - $25 Shipped - Neutral & Back-Up Light Switches - $15 Shipped Each Stickers [img]https://farm5.staticflickr.com/4330/36054755261_22d54da14b_k.jpg[/img] Cases - $20 Each Side + Shipping [img]https://farm5.staticflickr.com/4323/35352216934_62fc0d0195_k.jpg[/img] [img]https://farm5.staticflickr.com/4317/36054830501_f992ae39a1_k.jpg[/img] [img]https://farm5.staticflickr.com/4308/36187982115_858549efdd_k.jpg[/img] [img]https://farm5.staticflickr.com/4299/35352204304_d8abe32752_k.jpg[/img] [img]https://farm5.staticflickr.com/4326/36054830181_fdf2e9ed64_k.jpg[/img] [img]https://farm5.staticflickr.com/4292/36020454952_5fcaac7a45_k.jpg[/img] [img]https://farm5.staticflickr.com/4316/35352206594_6d14c3c8e4_k.jpg[/img] Front Differential - $60 Shipped [img]https://farm5.staticflickr.com/4303/36054829411_206c85df6d_k.jpg[/img] Shifter Arm & Joint - $30 Shipped [img]https://farm5.staticflickr.com/4298/36147034926_96fb3d183e_k.jpg[/img] 1st-2nd Shift Rod & Fork - $20 Shipped [img]https://farm5.staticflickr.com/4310/36187983125_8c10618920_k.jpg[/img] 3rd-4th Shift Rod & Fork - $20 Shipped [img]https://farm5.staticflickr.com/4309/35352207704_d45884e661_k.jpg[/img] Reverse Shifter Lever, Idler Gear (One Tooth Partially Chipped) & Shaft - $15 Shipped [img]https://farm5.staticflickr.com/4291/36147034396_85ce99d2c9_k.jpg[/img] Main Shaft – $30 Shipped [img]https://farm5.staticflickr.com/4319/35352218564_4e3be49204_k.jpg[/img] Drive Pinion Shaft - $40 Shipped (Due to Weight) [img]https://farm5.staticflickr.com/4311/36054829201_e1c2e8ce35_k.jpg[/img] Pitching Stopper Bracket & Release Fork Return Spring Bracket - $15 Shipped [img]https://farm5.staticflickr.com/4307/35352202874_65a4e88529_k.jpg[/img] Release Fork Cable Bracket - $10 Shipped [img]https://farm5.staticflickr.com/4328/36187981105_48959ac9c9_k.jpg[/img] Release Fork - $25 Shipped [img]https://farm5.staticflickr.com/4300/36054829611_50fd1f7a38_k.jpg[/img] Neutral & Back-Up Light Switches - $15 Shipped Each [img]https://farm5.staticflickr.com/4319/36020463912_1e78587996_k.jpg[/img] |
Bump!
More parts to come!
Bump!
Updated!
bump!
Updated! More goodies :)
Updated! :D
Sold a gas tank!
Great parts in great shape! Keep your baby going cheap :]
Updated!!
Updated!
Bump!
Bump!
bump!
