Duralast claims axle vibration due to worn transmission mount?
Old 11-25-2014, 10:52 AM
NoOneBetter's Avatar
Car Info: 2005 FXT
I recently replaced the front passenger side axle with a Duralast Gold axle and saw that it came with some information regarding vibrations from the axle and lay the cause to a worn transmission mount. Is there any merit to their statement? As it turns out, I also have a slow speed wobble coming from the axle most noticeable when in 1st and 2nd gear. I have a 2nd axle that I have yet to put in for the driver side since I am thinking about pulling the installed axle out and purchasing OEM remans from subaru or the HERI HD axles to avoid any more problems.
NoOneBetter is offline
Old 11-27-2014, 05:49 PM
Car Info: 2005 FXT
Update: Decided to upgrade to Group N transmission mount for added performance and also to see if this would fix the wobble feeling. After installing the mount there was still a slight wobble but less than before and mostly in first gear. Seems like the mount helped a little but did not completely alleviate the issue. I also decided to install the driver side axle and did not notice any ill effects from that axle so seems like the issue is isolated to only the passenger side axle.
sneezerboi
09-13-2006 10:37 AM
boka
08-31-2003 08:23 AM
wrxn'sx
07-24-2003 04:48 PM
mmboost
07-15-2003 01:13 PM
Quick Reply: Duralast claims axle vibration due to worn transmission mount?
