-   Wheel & Tire (https://www.i-club.com/forums/wheel-tire-59/)
-   -   wheel offset (https://www.i-club.com/forums/wheel-tire-59/wheel-offset-248436/)
mrt10wrx Feb 2, 2013 08:00 PM
wheel offset
new guy here, 1st subaru. probably a dumb question, but I see that the stock offset of my 2010 wrx is 55mm. I'm ready to put wheels on my car, but whenever I look at tire rack, discount tire etc. it shows me wheels that have 45-48mm offsets and I don't understand why? I don't want to modify anything, so shouldn't the wheels only be within a few mm of stock?
flat489 Feb 2, 2013 08:13 PM
[QUOTE=mrt10wrx;3350922]new guy here, 1st subaru. probably a dumb question, but I see that the stock offset of my 2010 wrx is 55mm. I'm ready to put wheels on my car, but whenever I look at tire rack, discount tire etc. it shows me wheels that have 45-48mm offsets and I don't understand why? I don't want to modify anything, so shouldn't the wheels only be within a few mm of stock?[/QUOTE]
Huh? are you saying you want wheels that are same size and offset as stock?
mrt10wrx Feb 2, 2013 08:26 PM
yes. staying with the 17"
JourdanWithaU Feb 2, 2013 08:54 PM
You don't want to modify anything. But you want different wheels?
55mm is a pretty high offset. Not a lot of cars have high offset wheels nor do a lot of consumers want high offset wheels. So the manufacturers make lower offset wheels.
48mm is within a few mm of 55mm. A lot of people run +48 without problems. A lot of people run +35 without problems. It's all up to you and what you want.
It looks like you have a '10 which is a narrow body so you don't have endless amounts of space like the widebody WRXs have. You just have to do a little bit of research to see what fits and what you like.
flat489 Feb 2, 2013 08:58 PM
[QUOTE=JourdanWithaU;3350936]You don't want to modify anything. But you want different wheels?
It looks like you have a '10 which is a narrow body so you don't have endless amounts of space like the widebody WRXs have. You just have to do a little bit of research to see what fits and what you like.[/QUOTE]
+1 [url=http://forums.nasioc.com/forums/showthread.php?t=2444100]The official '08-10 wrx thread - NASIOC[/url] cheers
mrt10wrx Feb 2, 2013 09:05 PM
I guess I'm just confused with the whole offset thing, even though I've researched it. I'm just not looking to lower the car, or have to mess with the fenders etc.
flat489 Feb 2, 2013 09:14 PM
[QUOTE=mrt10wrx;3350940]I guess I'm just confused with the whole offset thing, even though I've researched it. I'm just not looking to lower the car, or have to mess with the fenders etc.[/QUOTE]
did you not read jourdans post?
mrt10wrx Feb 2, 2013 09:34 PM
yep
Brfatal Feb 2, 2013 10:13 PM
Subaru's used high offset wheels, and as such their suspension geometry is designed for use with higher offsets. You want to run as high of an offset that you can while still having enough clearance for your struts. Generally speaking, you never want to go below a +42-45 offset. +48 is the most common offset for aftermarket Subarus wheels and work fine.
wrbdanny Feb 3, 2013 12:16 AM
[QUOTE="Brfatal"]Subaru's used high offset wheels, and as such their suspension geometry is designed for use with higher offsets. You want to run as high of an offset that you can while still having enough clearance for your struts. Generally speaking, you never want to go below a +42-45 offset. +48 is the most common offset for aftermarket Subarus wheels and work fine.[/QUOTE]
Brfatal, nobody gives a damn...
JourdanWithaU Feb 3, 2013 03:44 AM
[QUOTE=wrbdanny;3351002]Brfatal, nobody gives a damn...[/QUOTE]
Actually, his **** is pretty insightful.
Sometimes. :p
This is one of those times though.
WRX~Mike Feb 3, 2013 05:45 AM
I have a 2008 WRX and can be a bit of a wheel whore. I have had as low as a 30 offset and as high as the stock 53 offset. Never had a problem where I had to modify my suspension. The 30 offset did require me to do a small rear fender roll because they were 17x9.5. You'll be fine with a 45-48mm offset
Brfatal Feb 3, 2013 09:12 AM
....about? I'm sorry for answering his question? Perhaps you'd tell him to just get 18x11.5 -10s because it would make his car so JDM? :doh:
wrbdanny Feb 4, 2013 12:08 AM
[QUOTE=Brfatal;3351041]....about? I'm sorry for answering his question? Perhaps you'd tell him to just get 18x11.5 -10s because it would make his car so JDM? :doh:[/QUOTE]
with negative camber and stretched tires
mrt10wrx Feb 5, 2013 09:11 AM
The wheels are 40mm, so if wrx mike went as low as 30 without issues then it should be fine, thanks
