-   Wheel & Tire (https://www.i-club.com/forums/wheel-tire-59/)
-   -   35mm offset vs 48mm offset same width wheel? I'VE SEARCHED (https://www.i-club.com/forums/wheel-tire-59/35mm-offset-vs-48mm-offset-same-width-wheel-ive-searched-101798/)
LukeSTi Jun 7, 2005 10:52 PM
5-Zigen FN01-RC 17x8 +35mm offset which from my research puts the tire closer to the outside of the fender.
Rota Torque 17x8 +48mm offset.
From the offset info thread, for a 8in wide wheel the offset should generally be around +43 to +47. Most of the ~8in wide wheels I have seen are closer to +48.
My question is will the +35mm offset of the 5-Zigen wheels play havoc with the wheel bearings/be too close to the fender? Any help is greatly appreciated.
Z1 Performance Jun 17, 2005 05:29 AM
def an aggressive fitment - and def fender rolling out back
as for wheels bearings, its hard to say....we have lots of customers who had to replace bearings with stock wheels - I think it is more a maintenenace issue than anything else. Obviously the farther out you hang the wheel on the axle, the more you run the risk of wearing them prematurely
streetdevil Jun 22, 2005 12:43 PM
i wanna use my SSR 43 mm on the sti but holding it back because of the fitment issues.
Z1 Performance Jun 22, 2005 02:04 PM
43mm is not aggressive on an STi at all IMHO
streetdevil Jun 24, 2005 04:46 AM
thanks.....
Lik Aug 7, 2005 05:55 PM
with 43mm offset of 8 inch wheel or 7.5 inch... will u have rubbing issue? and will the wheel come too far out to hit the fender lip ?
Lik
