Positive Review: Torqued Performance - eTune
1 Attachment(s)
Tuner: [b]Eric of Torqued Performance[/b]
Type: [b]eTune using RomRaider, ECU Flash and OpenPort 2.0[/b] [B]Cliff Notes: Love the tune, looks safe, great turnaround, and great price![/B] Car: 2012 USDM STI - GR Hatch Mods: [quote] [B]Performance Mods:[/B] OpenPort 2.0 with Torqued Performance Stage 2 e-Tune Grimmspeed Downpipe - catted, coated, limited Grimmspeed 3 Inch Downpipe to Stock Exhaust Type Adapter Grimmspeed Heatshield Casper Electronics O2 Sensor Harness Extension (12 inch) Crawford AOS V2 Group-N Power Steering Cooler Mishimoto Thermostatic Oil Cooler Kit (MMOC-STI-08TBK) Mishimoto 2-Row Aluminum Performance Radiator (MMRAD-STI-08) Mishimoto Top Mount Intercooler (MMTMIC-STI-08) Stumble Mod Fix - GD Type Setup [B]Supporting Mods:[/B] Group-N Motor Mounts Group-N Transmission Mounts Group-N Pitch Stop Super Pro CrossMember Isolator Bushings Prothane Rear Diff Insert Bushing Kit [B](#16-1610BL[/B]) [B]Suspension Mods:[/B] GTWorx Bilstein Struts (Impreza Cup Kit) Racecomp Engineering Regular Guy Springs HVT Non-Lowering Camber Plates SuperPro 22MM Rear Sway Bar (Set to Soft) SuperPro Rear EndLinks SPC Rear Camber Arm (67660) AVO Rear Sway Bar Mount Reinforcement [B]Interior Mods:[/B] STI Short Throw Shifter Hydro-Dipped CF JDM Dual Din Radio Bezel Hydro-Dipped CF Shifter Surround STI Red Shifter Knob from 2015 DAMD D-Shaped Steering Wheel Redline Leather Shifter Boot Redline Leather Parking Boot WeatherTech Floor Liners Pioneer AVIC-X920BT w/ ASWC-1 JDM Arm Rest Extension JCS Dual Pillar Gauge Pod Zeitronix ZT-3 / ZR-3 Gauge Wideband Gauge (Red) ProSport Premium Boost Gauge (White Pointer) [B]Exterior Mods:[/B] Clear Bra (Full Hood / Front Bumper / Side Fenders) Rally Armor Mud Flaps (UR) [/quote] Previously had a COBB AP and Stage 2 ACN91 OTS Tune, decided to go with an Open Source tune from Eric of Torqued Performance (per great personal reviews from other dublin meet folks). Also had the the infamous GR 2500K RPM stumble from time to time which I hated . The first thing I noticed about Eric, he replies too darned quick, I am not sure if the guy sleeps - lol. First thing he stated was that he won't tune the car if it didn't have the fuel line extension mod, or the iaPerformance or Cobb stumble fix. Fair enough, the stumbles suck and a mechanical fix cures most of it with the rest being a good tune. Decided to create this [URL="https://www.i-club.com/forums/how-tos-installations-192/howto-gr-stumble-mod-workaround-2008-2015-sti-262010"]HOWTO / WRITEUP [/URL] (money saved can go towards a wideband IMO).. He gave me a base map which I flashed and asked me to take a 15-minute cruise log, and some 3RD gear WOT pulls from 2500 -> 6500 logging the following parameters in RomRaider. Note: [b]some extended parameters in ROMRAIDER won't show up until you plug the laptop into the car[/b] [b] A/F Correction #1(%) A/F Learning #1(%) A/F Sensor #1(AFR) Engine Load (4-byte)* (g/rev) Engine Speed Feedback Knock Correction (4-byte)* Fine Learning Knock Correction IAM Ignition Total Timing Injector Duty Cycle Intake Air Temperature Manifold Absolute Pressure (PSI) Manifold Relative Pressure(corrected)(PSI) Mass Airflow (g/s) Mass Airflow Sensor Voltage Throttle Opening Angle(%) Vehicle Speed (mph) [/b] I also threw in the Wideband Output from my Zeitronix ZT-3 as the calculated AFR from the front O2 sensor on the Subaru doesn't read richer than 11.1. The REV1 map was the basemap and was to be used to initially dial the car, considering it's supposed to be extremely safe, IDC was through the roof, and the AFRs were definitely not CARB legal - lol.. Sent him 2 cruise logs, and 3 - 3RD gear pulls. [b]next day, I get an e-mail stating - here's your REV2 map[/b], and please do some pulls when you get a chance. I was like, does this guy sleep? That night, data logged the REV2 map - air fuel ratio's you can land a plane on, total timing at peak torque was around 10 degrees (advanced) - rising to around 18 degrees by 6500 RPM. Nothing in the fine learn knock, or feedback knock. Sent him the logs and [b]30 minutes later[/b] he e-mails me, he's your REV3 map and let me know how it goes. Whuut? Getting a response in 30 minutes? Does this guy not sleep? No wife? Flashed it the next day and data logged the REV3 map - air fuel ratio's you can land a plane on, total timing at peak torque was set to 11 degrees (advanced) - rising to around 19 degrees by 6500 RPM. Nothing in the fine learn knock, or feedback knock. Sent him the logs and we are both pretty happy with it, asked me to take a log after 200 miles to see how it's learning.. [URL=http://s129.photobucket.com/user/gfunks/media/STI/REV2_vs_REV3_zpsbeac4c5f.jpg.html][ATTACH]99923[/ATTACH][/URL] |
