another tune by Ed@Eq tuning
2007 Sti aka Subrina
modlist: Titek catted Dp 3" Borla Hush 3" walbro fuel pump outside temp 96 deg F intake temps 140-170 274whp/ 296tq 10.8AFR on spoolup down to 10.6AFR by redline 19.5 max psi after 10k miles of daily driving the jerkyness and the unnecessary stress on the motor had to end I finally said enough is enough "I deserve better" i scheduled my tune last minute with Ed. Ed was more than accomadating I typically have a very tight work schedule and he filled me into his already tight schedule two days later. key factors I wanted from the tune was smooth acceleration throughout the powerband, a safe reliable tune, DD drivability, good throttle response low and high, boost to come in quickly when needed. Ed showed me different variations in how throttle relation would effect how much and how fast boost would kick in then let me decide which I liked best. The end result was a progressive throttle power was available at all throttle angles and it pulled smoothly through all the gears. to date one week later the car feels amazingly better than the day of the tune mostly due to the high temps that week and heat soak. if I could make any changes to the tune I wouldnt, I love it too much. :) Special thanks to Ed @eq tuning!! |
awesome! another happy EQ customer. :)
Hey Fred,
I'm glad you're enjoying the tune. That's really how the car should drive from the factory... I don't know what they were thinking with the stock 07 calibration! Here is your chart: [img]http://eqtuning.com/dynos/freds/91%20octane.png[/img] Thanks |
Great job again Ed. Damn 2.5 block makes so much torque.
272whp/258wtq on 03 bugeye w/ vf43 =) Thanks again Ed! |
good choice, lot of 07's have blown supposedly due to a bad factory tune and this seems to be absolutely true. Ed tricked you tho, he really works for Balco.
[QUOTE=slow04wrx;2311067]good choice, lot of 07's have blown supposedly due to a bad factory tune and this seems to be absolutely true. Ed tricked you tho, he really works for Balco.[/QUOTE]
The 07 stock calibrations should really be made illegal... no excuse for something that dangerous to the engine to come out of the factory. BTW... what the heck is Balco? :lol: |
[url]http://en.wikipedia.org/wiki/BALCO[/url]
The drug company with all the big steroids scandals in baseball lately. |
:lol: thanks.
Good power for only exhaust and fuel pump.
[QUOTE=subie OCD;2312862]Good power for only exhaust and fuel pump.[/QUOTE]
Yep... not bad at all for the conditions. I was hoping to get over 300ft-lbs, but considering the heat we were both happy with the numbers and especially the overall feel of the car. |
would a 04 put out similar numbers with those mods?
[QUOTE=ViVaSuBy;2335476]would a 04 put out similar numbers with those mods?[/QUOTE]
Yep, I generally see similar power from 04-06 STI's with the same mods. |
hey ed wuts a guesstament amount a typical tune will cast me
[QUOTE=pancho;2335633]hey ed wuts a guesstament amount a typical tune will cast me[/QUOTE]
Most basic setups are $350 flat rate, and I end up spending 2-3 hours on them. Thanks |
how much more hp and torque can i gain with no mods except perrin pulley
