Need help choosing strut/ spring combo
Old Jul 16, 2013 | 10:07 AM
SnowDuner02's Avatar
Car Info: 2002 subaru impreza wrx
I just installed new perrin sway bars in the front and rear. Now I'm looking to install new struts because the rear end makes a lot of cracking noise when I carry people with me and go over bumps. My car is stock height right now with 215x45x17 tires.
My cousin is runnin Megan Racing Track Series Coilovers and he like them. But i wanna see what others say.And some ppl said I should look more into strut spring combo. I would not mind lowering it 1-1.5 inches maxxx.
I want to be able to carry 3 other ppl in my car and not worry about scrapin, I would like a smooth ride not too bumpy. It's pretty much just a daily driver car and during the winter time I spend a lot of my time up in the mountains in the snow.
What combo have u guys tried and liked
Old Jul 16, 2013 | 10:10 AM
Oh and i drive an 02 wrx sedan with STI pinks
Old Jul 16, 2013 | 10:22 AM
norcalbro's Avatar
Car Info: 2010 swp WRX hatch
Koni yellows.
/thread
Forget coilovers. They are going to be cheap and horrible ride quality or nice ride but $3000...
Koni yellows have adjustable stiffness and ride awesome!
Old Jul 16, 2013 | 10:53 AM
JourdanWithaU's Avatar
^+1 on the Konis. I have a set and I love them.
For Springs, I have heard great things about RCE.
Old Jul 16, 2013 | 11:02 AM
It seems like you guys are in CALI too so you know the type of roads. Are your cars lowered at all?
Old Jul 16, 2013 | 11:08 AM
I'm on stock springs, but the height has dropped a bit from the Konis.
However, the car used to be a lot lower when it was on ****ty coilovers.
Old Jul 16, 2013 | 11:10 AM
debbid's Avatar
My car is on RCE Black Springs and Tokico D-Specs. I like this combo but I have great things about Konis as well.
I've had coilover in the past (Tein Flex and Helix DNAs) and I would go with springs/struts. OP, you can get the ride you are looking for from springs/struts; no need for coilovers.
Old Jul 16, 2013 | 11:38 AM
norcalbro's Avatar
I'm lowered on eibach springs. They ride pretty nice.
I had bc br coilovers before, trust me, don't do it...
Check out Rce or swift springs.
Old Jul 16, 2013 | 11:46 AM
So if I was to go to coil overs , I have to swap out my STI pinks?
Old Jul 16, 2013 | 11:55 AM
Yes
Old Jul 16, 2013 | 12:02 PM
Oh ok and why is that
Old Jul 16, 2013 | 12:10 PM
A coilover set-up replaces the entire spring/strut assembly.
Springs/struts
Coilovers
They're both built in a similar way, but the components, in this case, springs, are not interchangeable.
Old Jul 16, 2013 | 12:35 PM
04GG's Avatar
If in doubt, FLAT OUT
What endlinks did you get? The bars should not make noise unless the bushings were not lubed properly, but some of their endlinks are known to. Did you also upgrade the rear mounts? Heavier sways will put a lot of stress on the stock mounts.
It is entirely possible the springs are making noise as well, because I've heard that about pinks more than once.
Old Jul 16, 2013 | 12:47 PM
Well I got the car like that I haven't done anything besides the sways. I did some research online and I think there white line spherical
Old Jul 16, 2013 | 01:04 PM
Deniz1980's Avatar
Car Info: WRB 2012 WRX Sedan
Go with GTWORX/ Bilisten RCE yellow cup kit...
