Coilovers adjust help needed
So I got some bc coils couple of week ago
For my hatch so I went ahead and install them THE way they came two week later I cut my fenders Put my flares and new wheels and I had to adjust THE ride height but run in to something weird In the rear my fender gap are even but coils are not even IS like 3/4 difference one side is showing 2 1/4 and the other IS 1 1/4 between spring perch and lower collar Is there something wrong with them |
2.25 and 1.25 isn't a .75 difference... What are these measurements? Inches? Centimeters? Threads?
Were things even before you cut your fenders? |
My bad I was a bit tired last night is almost 1 inch difference
In the showing treads of the coils I don't think they where like this before cuz I mesure them all the same before the install And didn't do any adjustment at the time I put them on After the new wheels and the flares that happened By the way they're bc coils |
The flares were cut and mounted evenly?
Yeah I check everything line up the same
I was thinking maybe my upper control arm bushing Are binding causing not to go down all the way Or there's not enough weight on that side to compress The spring |
Is the subframe flat to the chassis?
You would need a lot of weight to compress one side. You bushings would have to really be binding to make a difference as well. Have you corner balanced the car? |
Chassis and subframe are flat
Haven't balance the car yet because tha issue I'm kinda worrie I'm trying to foxy before I go for alignment And balance I check prelude on the preload on the spring they're Same I don't know what to do now |
That's why I post here see if someone has had the same problem or it's just me
| All times are GMT -7. The time now is 08:43 PM. |
