Coilovers adjust help needed
Car Info: 2010 sti hatchback
So I got some bc coils couple of week ago
For my hatch so I went ahead and install them
THE way they came two week later I cut my fenders
Put my flares and new wheels and I had to adjust
THE ride height but run in to something weird
In the rear my fender gap are even but coils are not even
IS like 3/4 difference one side is showing 2 1/4 and the other
IS 1 1/4 between spring perch and lower collar
Is there something wrong with them
My bad I was a bit tired last night is almost 1 inch difference
In the showing treads of the coils
I don't think they where like this before cuz I mesure them all the same before the install
And didn't do any adjustment at the time I put them on
After the new wheels and the flares that happened
By the way they're bc coils
Yeah I check everything line up the same
I was thinking maybe my upper control arm bushing
Are binding causing not to go down all the way
Or there's not enough weight on that side to compress
The spring
The spring
Is the subframe flat to the chassis?
You would need a lot of weight to compress one side. You bushings would have to really be binding to make a difference as well.
Have you corner balanced the car?
Chassis and subframe are flat
Haven't balance the car yet because tha issue
I'm kinda worrie I'm trying to foxy before I go for alignment
And balance
I check prelude on the preload on the spring they're
Same I don't know what to do now
And balance
JJMT
Jun 15, 2015 08:17 PM
youie
Mar 19, 2003 06:30 AM
