Wheel Fitment for Nt03 18x9.5 +40 on 02 GD
Car Info: bugeye
Heey whats up guys. I am a happy buyer of my new Enkei NT03's! I just did a text fitment yesterday and the rim are a few mm's away from my strut. I have v7 STI pink struts and springs. I'm rolled on all four of my fenders as well. The tires i will be running on this set is 245/40/18. I plan to put 5mm spacers in the rear to clear this gap from the wheel to the struts. Basically my question is will i still be rubbing? Or do you guys know anyone running this same set up on their bugeye rex's? Thanks guys! any input is greatly appreciated!
Car Info: 1998 M3, 2016 WRX
You'll most likely clear the struts no problem, but now you have to worry about rubbing your fenders. I ran the same wheels with 5mm spacers but with 255/35/18s and still rubbed a little on my fenders with a roll. Wasn't bad since it only rubbed on bumps at highway speeds and cornering super hard. I was on coilovers as well.
Car Info: bugeye
Car Info: bugeye
The +40 offset sits awesome with the body and pretty flush. So im sure with a 5mm spacer im gonna be rubbing a little too. But hopefully not much more than you did with my tire specs.
Im running the same wheels and fitment with 255/35/18 r-comp tires on coilovers, with a 3mm spacer, and there is no rubbing at all. I have all four fenders rolled as well. Post a pic of your car! I like buyeyes with NT03's!
Car Info: bugeye
Sorry for the late reply, i just comped on some Feal 441s from a member on here and im looking for tires now. As soon as i get those ill have everything mounted and ill take pictures!
AspenTrWrx
Apr 20, 2011 12:29 PM
