correcting uneven pad deposition?
Old Aug 20, 2007 | 03:35 PM
nicknaz's Avatar
Car Info: 328i
Hi guys,
I went to thunderhill yesterday and I am pretty sure I got some uneven pad deposition (steering wheel and pedal shudder under braking, there are some spots on the rotor)
I suspect this was caused by not cooling down the brake pads appropriately between sessions (i just parked after my session, didn't drive around the paddock.. i didn't think i was that hard on the brakes yesterday....)
Does anyone have any suggestions on how I can correct this? I read on the stoptech site that I could swap in a set of Hawk Blue brake pads to scrub the rotor clean. I don't have a set of hawk blues handy.. so is there anything else I can do to correct this problem?
thanks!
Old Aug 23, 2007 | 08:09 PM
dynamic_klink's Avatar
Car Info: 2005 Honda Civic
from what you're describing, sounds like the rotors are warped, i'd just suggest getting new rotors.
Old Sep 1, 2007 | 08:15 AM
Group B's Avatar
Dahveed aka Robin Hood
What is your current brake setup (pads, rotors, calipers, lines, fluid)
If you swapped-in different pads for Thunderhill, which ones did you use?
You'd be surprised at how hard a track day can be on brakes.
JTech
Feb 12, 2005 10:54 PM
sjscooby
May 3, 2004 09:19 PM
sal
Apr 26, 2004 08:29 PM
Scooby_WL
Oct 3, 2003 11:24 AM
daybreak
Apr 14, 2003 10:54 PM
