RallySport Direct has a great selection of Stoptech products!
Former Sponsor
Car Info: GC,GF,GD,GR,GH
RallySport Direct carries a large line of Stoptech products. Whether if you need new brake pads, rotors, or even an upgraded big brake kit, we offer a wide variety of Stoptech products to suit your needs. Below are a few examples of the fine products from our friends at Stoptech.
Stoptech PosiQuiet Semi-Metallic Brake Pads Front Subaru STI / Mitsubishi EVO / OEM Brembo Applications
$34.02
Available for most Japanese and domestic models, PosiQuiet Semi-Metallic pads offer bite levels similar to or greater than OEM formulas with reduced levels of noise and dust. Well suited to performance street driving under all weather conditions.
StopTech PosiQuiet Brake Pads are manufactured using the same positive molding process utilized by Original Equipment suppliers. Positive molding uses extreme pressure to compress the friction material and bond it to the backing plate. This process assures consistent friction material density throughout the pad, resulting in even wear and performance characteristics throughout the life of the brake pad. StopTech PosiQuiet Brake Pads features either precision cut or shaved backing plates and mechanically attached shims. These small details ensure proper fitment in the caliper and virtually eliminate noise associated with pad vibration. In addition to these features StopTech has added a scorching process to all of its PosiQuiet Brake Pads. This scorching process forces any impurities out of the friction material and pre-burnishes the pads to greatly accelerate the break-in process. Scorching raises initial cold effectiveness, stabilizes friction levels right out of the box, provides consistent performance across the entire operating range.
Stoptech Street Performance Brake Pads Front Subaru STI / Mitsubishi EVO / OEM Brembo Applications
$49.83
Stoptech street performance brake pads are engineered to meet the demands of high performance driving while maintaining the refinement and comfort expected in everyday driving conditions. Stoptech brake pads combine the benefits of premium street brake pads with aggressive friction formulas suitable for aggressive street and autocross use. Stoptech has found the perfect combination of aggressive braking and everyday weather resistant braking with these Street Performance pads.
Stoptech Sport Kit Subaru STI 2005-2007
$698.80
The StopTech Sport Kit is an excellent choice for the enthusiast whose rotors are nearing the end of their service life. StopTech's Sport Kit includes direct replacement OE diameter rotors at all four corners, performance brake pads front and rear and stainless steel brake lines all around. . Stainless steel lines provide immediate response to brake pedal input and give better feedback. Performance brake pads offer improved stopping power in all conditions with less dust than other pads. Quality is assured as all components are manufactured to meet or exceed all OE specifications.
Kit Includes:
2x Front Slotted Rotors
2x Rear Slotted Rotors
F/R Stoptech Street Performance Pads F/R SS Brake Lines
Stoptech Stainless Steel Brake Lines Front Subaru STI 2004-2007 / WRX 2006-2007
$57.00
StopTech stainless steel brake lines improve pedal feel and reduce the amount of time between applied pedal pressure and actual deceleration by preventing expansion, which stock rubber flex lines allow. This provides a quicker pedal response, and allows the driver to maintain consistent brake pressure and precision brake modulation.
StopTech brake lines consist of a Teflon inner line that is covered with a layer of stainless steel woven braid. The Teflon tube is very resistant to expansion under pressure and will not degrade from exposure to brake fluid. The stainless steel braid provides support for the Teflon and the weave is extremely durable against incidental impact and abrasion. StopTech brake lines feature a Clear Abrasion Resistant Cover for maximum protection against chaffing
All StopTech Stainless Steel Brake Lines are DOT (United States Department of Transportation) compliant and 100% tested to a pressure of 4500 psi.
[/COLOR]
Stoptech STR660 Brake Fluid DOT 4 500ml
$26.59
Like all StopTech products, StopTech High Performance Brake Fluid is carefully designed to give drivers an edge in the punishing world of high performance motoring. For over a decade StopTech has engineered and delivered race- and championship-winning brake components and systems for high performance street driving as well as pure racing. StopTech High Performance Brake Fluid adds a new dimension to the company’s offerings.
Available in STR-600 and STR-660 formulations for high performance street and racing applications respectively, the new StopTech High Performance Brake Fluid is a DOT 4 motor vehicle brake fluid, engineered to optimize brake system performance at high operating temperatures. In addition to guarding against boiling and subsequent loss of efficiency at severe racing temperatures, StopTech Brake Fluid maintains its excellent viscosity, lubricity and non-compressibility.
StopTech Racing Brake Fluid stands out not just for its exceptional performance, but also for its stylish and functional packaging. StopTech Brake Fluid comes bottled in a special metal container that is not only more durable, but also gives the fluid up to 25 percent longer shelf life than typical plastic bottles provide. Both in looks and in performance, StopTech Brake Fluid stands out from the crowd.
StopTech® High Performance Brake Fluid conforms to and exceeds the current specification of U.S. FMVSS 116 (§ 571.116) DOT 4, is road legal, and compatible with modern ABS and other vehicle dynamic control systems. StopTech brake fluid is mixable with all DOT 3 and 4 products.
Stoptech ST-40 Big Brake Kit Front 332mm Red Slotted Rotors Subaru STI 2004-2007 (fits both 5x100 / 5x114.3)
$2,370.25
At the end of the day, you can only get so much braking performance out of your brakes before the rotors and calipers are just not able to keep up. This is where the StopTech 332mm 4 piston big brake kit steps in.
This model specific kit is designed to work with the OEM rear calipers, allowing for the brake balance to stay proper while increasing overall braking performance in every aspect. Initially the biggest noticeable difference is felt in the pedal feedback, with shorter travel and firmer feel while stopping the car much faster with the same amount of pressure. The other aspect that will be noticed by track drivers is that the brakes are able to hold allot more heat allowing for much more constant lap times over and over. This is achieved by using a larger then OEM brake pad, matched up to a larger rotor that is able to hold more heat and also get rid of it much faster do to the taller and also thicker design.
These are full kits, and include everything you would need to install this on your car (these clear the OEM BBS Wheels).
The kit contains the following:
Calipers
Set of Street Compound brake Pads
Rotors
Brake Lines
Brackets
Hardware
Lock Tight
Detailed how to instructions
Don’t overlook the most important aspect of your car, as without control power is nothing!
To view our full line of Stoptech products, click here.
FREE UPS GROUND SHIPPING ON ORDERS ABOVE $200
Former Sponsor
Looks like we have the Stoptech Street Performance here in stock.
Stoptech Street Performance Front
Stoptech Street Performance Rear
Thanks,
Rick
Thanks,
Rick
Former Sponsor
This should have your whole brake system covered.
Stoptech Sport Kit Subaru WRX 2008 977.47007 at RallySportDirect.com
Kirill
Kirill
Kirill
Kirill
RallySportDirect
53
11-24-2015 03:18 PM
RallySportDirect
Engine and Drivetrain
07-21-2015 09:38 AM
RallySportDirect
07-21-2015 09:37 AM
RallySportDirect
07-14-2015 01:14 PM
RallySportDirect
14
07-09-2015 02:45 PM
