Cusco back in stock. STi, Endless, Porterfield, Brembo items. Legacy Parts too!
Cusco:
Cusco Type CB (Carbon Fiber) Strut Tower Bar - Rear - 02+ WRX / 04+ STi
Suspension upgrades such as high performance springs, shocks and tires can add additional stress to the chassis resulting in additional chassis flex. Cusco Type-CB strutbars improve chassis rigidity and reduce this flex. The all carbon fiber shaft is lighter than most other bars and adds a serious race quality to the vehicle.
$220 shipped
Cusco Type OS-T Triangle Brace - Rear - 02+ WRX / 04+ STi
Suspension upgrades such as high performance springs, shocks and tires can add additional stress to the chassis resulting in additional chassis flex. Cusco Type-OS improve chassis rigidity and reduce this flex. Lightweight aluminum and high rigidity oval sectioned pipe used.
*Only includes the triangle brace, not the rear strut tower bar.
$125 shipped
$265 shipped w/ Type OS Rear Bar (as pictured below)
Cusco Rear Suframe Brace and STi Rear Diffuser- 02+ WRX / 04+ STi
-Rear subframe brace is designed specifically for STi rear diffuser.
-Allows easy installation of 06 STi rear diffuser on 02-05 MYs.
-Stiffens chasis resulting in crisper vehicle dynamics and improved handling.
$249 shipped
Cusco Pillowball Upper Mounts - 02+ WRX / 04+ STi
-Designed to work with your stock struts.
-The full pillowball design controls unwanted forces under acceleration and braking. Stable steering response in essense and lane changing improved stability over bumps and holds roll in corners. Enables linear handling and keeps you on the record line better. Stability and safety during turn-ins and under braking. Camber adjustable by sliding the plate and pillowball sections.
$219 shipped for Rear
Cusco 22mm Rear Sway Bar - 04+ STi
-The addition of stiffer swaybars properly distributes cornering forces by reducing lateral sway applying increased cornering force on the outside wheel and will ultimately increase vehicle turning characteristics. The rear sway bar will promote rotation at the rear of the car, while the front sway bar will promote rotation at the front of the car.
$155 shipped
$239 shipped with Helix STi Rear Endlinks (Full Pillowball) - 04+ STi
Cusco 21mm Front Sway Bar - 02+ WRX
$155 shipped
$239 shipped with Helix Front Endlinks (Full Pillowball) - 02+ WRX Wagon
Cusco V2 Lower Arm Bar - 02+ WRX / 04+ STi
-The purpose of the Cusco lower arm bar is to reduce alinement flexing and improve body rigidity. The lateral arm improves body and rigidity by connecting at the lower arm points. Thus preventing body flex and therefore dramatically improving steering, throttle response and traction. The Version II Bar mounts by multiple bolts and the lateral and foe aft rigidity is greatly increased over Version I.
$150 shipped!!!
STi items:
STi Lateral Link Set (Full Pillowball) - 02-05 WRX
The six piece STi rear lateral link set upgrades all 8 link bushings to pillow ball type joints (spherical bearings) sealed against dirt intrusion. Also includes metal (w/ uniball joints) rear swaybar links with adapter brackets. With ultra-low compliance joints, this lateral link set significantly improves rear alignment control, handling response, and feedback. There will also be a slight increase in noise and vibration. The trailing arms replace the rear front trailing link bushing with pillow ball joints. Completes the set of rear suspension members when combined with one of the lateral link sets.
$525 shipped!!!
Thanks,
Preston
Phone: (510) 783-5300
We Accept Paypal!
Paypal: sales@gruppe-s.com
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Preston
Price including shipping: $XXXX
Shipping address.
$220 shipped
$125 shipped
$249 shipped
$155 shipped
$155 shipped
$150 shipped!!!
STi items:
$525 shipped!!!
Thanks,
Preston
We Accept Paypal!
product name: XXXX
sales rep: Preston
Shipping address.
Endlinks:
Helix Rear Endlinks - 02+ WRX
-Helix Solid Endlinks are CNC machined from high strength aluminum. This makes an excellent replacement for your factory plastic endlinks which tend to twist and bend upon corner-loading. The addition of Helix Solid Endlinks significantly increases cornering response and tightness, regardless of the use of an aftermarket sway bar or not. The use of spherical bearings allows for a much wider range of angular movement and eliminates the squeaking and creaking associated with the deterioration of rubber or urethane bushings. The spherical bearings are teflon coated to prevent dirt and debris from fouling movement.
$99 shipped!!!
Helix Front Endlinks - 02+ WRX Wagon
$99 shipped!!!
$ 99 shipped!!!
STi Replica - Front - 02+ WRX / 04+ STi - $75 Shipped
Suspension upgrades such as high performance springs, shocks and tires can add additional stress to the chassis resulting in additional chassis flex. These STi Replica Strutbars improve chassis rigidity and reduce this flex. By using a monocoque aluminum tube shaft, high strength and rigidity are obtained without unnecessary weight gain.
Brakes:
GD Vaned and Slotted 2 Piece Direct Replacement Rotors for 04/05 STi
In stock and ready to ship; the best bang for the buck 2-piece rotors!! Replacement rotors available now too!
Gruppe-S is happy to announce that we finally offer some affordable high quality 2 piece direct replacement rotors for the front of your STi!
-Retains stock Brembo calipers
-6 lbs. lighter per rotor than stock (equivalent to a total loss of 60 lbs. on the front of your car)
-Aircraft grade hardware (non-floating design)
-Zinc coated rotors
-Vaned and slotted
-Track tested
$549 + Shipping!
Special Brake Packages for the STi:
We all know that STi comes with awesome calipers but we unfortunately can't say the same thing about the pads, rotors, and lines. Sooooo, here's the stuff you really need!
Porterfield R4-S Brake Pads (carbon kevlar), 04+ STi, F/R
These pads are a good balance between race pads and street pads. The Porterfield R4-S’ are unique because they’ll withstand 20 minutes of track time with no fade (they so not fade at temperatures up to 1,100 degrees F) but at the same time, they will work fine when cold and they’re very rotor friendly (as well as being very slow wearing). The R4-S friction level will give you an impressive increase in stopping ability with very minimum pedal effort. The R4-S compound also has the absolute lowest noise and dust levels, far below OEM equipment or any other high performance brakes material.
Good for autocrossing, drivers schools, weekend track sessions, solo events, and rallys.
$199 shipped for F, $269 shipped for F and R!!!
Endless SSS Pads, 04+ STi, F/R
These pads are an excellent choice for the agressive street driver. They are non-metalic so they are rotor friendly and dust is minimal. The SSS feature a high friction coefficient so they are suitable for short weekend track stints but are not applicable for heavy track use.
$179 shipped for F, $340 shipped for F and R!!!
Goodridge Stainless Steel Brakelines
$115 shipped!!!
-Improves pedal feel
-Gets rid of unwanted line flex
-More durable than stock
Brembo Sport Replacement Rotors (Drilled or Slotted) - F/R - 04 STi only
~Brembo Sport slotted brake rotors are for drivers who want to improve the
looks and performance of their vehicle's original braking system without
having to change additional brake components.
~Brembo Sport slotted and drilled brake rotors provide excellent stopping
power in everyday traffic, as well as high performance street and track
driving.
~Brembo Sport slotted brake rotors match the vehicle's original equipment
rotor's dimensions and are fully compatible with its hubs, brake calipers
and road wheels.
$394 shipped for F, $375 shipped for R!!!
OK, now for the packages:
04 STi Front:
1) Porterfield R4-S Pads F, Brembo rotors F, Goodridge SS lines F+R: $675 shipped!!!
2) Endless SSS Pads F, Brembo rotors F, Goodridge SS lines F+R: $655 shipped!!!
3) Porterfield R4-S Pads F+R, Brembo rotors F+R, Goodridge SS lines F+R: $1110 shipped!!!
4) Endless SSS Pads F+R, Brembo rotors F+R, Goodridge SS lines F+R: $1180 shipped!!!
Special Brake Packages for the WRX:
Gruppe-S finally carrys Motul Fluid! People have been asking for some cheap effective brake combos for their WRXs for quite some time now. This is the most cost effective way to improve your brakes.
Porterfield R4S Pads + Goodridge SS Lines + Motul RBF600 Fluid
*The Goodridge Stainless Steel Brake Lines will improve your pedal feel and stop unwanted line flex at high temp.
*The Porterfield R4S Carbon Kevlar Brake Pads have a superior coefficient of friction compared to the stock pads and have excellent fade characteristics. They'll take 20 minutes of weekend track time for beginner to intermediate drivers with no ill effects
*2 Pints of Motul RBF600 Brake Fluid are more than enough to flush your entire brake system. This is some of the best brake fluid out there (DOT4) and is track worthy stuff.
All 4 Corners for 02 WRX - $299 Shipped
All 4 Corners for 03+ WRX - $319 Shipped
If there's a package that you'd like and it's not listed, please don't hesitate to ask for pricing.
Thanks,
Preston
We Accept Paypal!
product name: XXXX
sales rep: Preston/Geoff
Shipping address.
$99 shipped!!!
$99 shipped!!!
$ 99 shipped!!!
Brakes:
-Zinc coated rotors
-Vaned and slotted
-Track tested
$549 + Shipping!
$115 shipped!!!
driving.
and road wheels.
04 STi Front:
Thanks,
Preston
We Accept Paypal!
product name: XXXX
Shipping address.
Legacy items in stock and ready to ship!!!
Endless SSS Pads, F+R, Goodridge SS Lines, and 1L Motul Brakefluid - $535 shipped!
These are an ideal pad for the spirited street driver. They'll even work for 20 minutes of track time. They're low dust, quiet, and rotor friendly. The lines will increase pedal by stopping unwanted flex and Motul Brake Fluid is some of the best that you can buy. An awesome package for an agressive street driver or a beginner to intermediate track driver.
STi Pink Springs - 05 Legacy GT, Sedan/Wagon - $379 shipped
These can be used with your stock struts and will lower your car 15mm. Expect better handling as a result of lowered center of gravity and stiffer springs rates.
STi Front Strut Tower Bar - 05 Legacy GT, Sedan/Wagon - $255 shipped
Cusco Type II Lower Arm Bar, Front - Legacy GT Sedan / Wagon 05+ - $149 Shipped
The Type II lower arm bar is made of tubular aluminum to help reduce weight over the stock bracing without compromising strength. Coated in the classic Cusco blue paint, it offers years of protection against the elements while adding to the overall look of the bar. The Type II bar is a multi-point setup and includes all the required hardware for installation. It bolts on easily using normal hand tools.
Cusco Type II Lower Arm Bar, Rear - Legacy GT Sedan / Wagon 05+ - $149 Shipped
Thanks,
Preston
We Accept Paypal!
product name: XXXX
Shipping address.
Thanks,
Preston
We Accept Paypal!
product name: XXXX
Shipping address.
Location: Yea, you like my JDM backside. Quit staring ^^
Hey Preston, how much for the type OS rear upper strut for a 05 WRX Wagon picked up , and do you have any idea if the V Brace will fit a wagon?
thanks,
Preston
gruppe-s
09-18-2006 05:20 PM
gruppe-s
09-07-2006 12:14 PM
gruppe-s
03-22-2006 04:34 PM
gruppe-s
03-22-2006 03:48 PM
