| snowjob |
Sep 19, 2005 06:43 PM |
EJ22T closed Deck block with oil squirters
[url]http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=8001612956[/url]
You are looking at a closed deck shortblock from a 1992 EJ22t turbo legacy. This block has oil squirters and can hold 30 psi with no problem. This block was the building block for the famous Subaru 22B. Heads of a SOHC 2.5L engine, or from a WRX will bolt right up. The block will also bolt to any subaru transmission. The engine was running fine before the part out, so you can either put it in as is, or build the block while it's out. Please ask questions before bidding. This Auction is for the Block only, no heads are included.
Good luck on one of Subaru's strongest Blocks.
