Please help cobb v2 ecu problem!
Old May 10, 2015 | 11:45 AM
Agamaojared's Avatar
Car Info: 2002 wrx
So I just received installed my motor with mod list below.
I have received my basemap from torqued performance and it ran good for about an hour and a half while I drive it home. Then the next morning the ap showed recovery mode (I accidentally left it plugged in) so I uninstalled, and when I tried to reinstall it couldn't communicate with ecu. And the fuel pump would not stop priming! So I figured I bricked it and went and found another ecu. I just reflashed my basemap on to it and it completed perfectly. Now SAME THING. Fuel pump primes and primes and primes. Car does not start and access port cannot connect to my car. Has anyone ever had this happen to them?
2.5 bottom end
Matched 2.0 head
tGV butterfly delete
Perrin elbow and turbo xs intake with stock maf
Cobb ebcs
Arp head studs
Super tech valve train
Kelford r-199-b cams
Forged ej257 crankshaft
P&L spec h beam rods
Cp pistons and cp performance rings
ACL rod bearings
Oem sti oil pump and moroso pan
Turbo xs fmic
Hks Ssqv blow off valve
BNR 18g internally gated
Catless invidia bellmouth dp
Uel headers with catless up pipe (think its a perrin)
Deutchworks 300 fuel pump
TSM 980cc top feed injectors
Cobb access port v2
Perrin lightweight crank pulley
Stock 5 speed transmission
Competition clutch stage 2
ACT street light flywheel
ninjaboy76
Sep 25, 2005 10:35 AM
diz
Jun 3, 2005 01:33 PM
FostersAFB
Sep 8, 2004 04:04 PM
blueberryrex
Apr 17, 2004 02:25 PM
GottaREX
Wanted
Feb 22, 2004 07:13 PM
