need professional help
i own a 06 sti and i have
- APS Front Mount Intercooler - APS FMIC Blow Off Valve - APS Cold Air Intake - APS 3.5 Turbo Back W/ Race Pipe - Hydra Standalone ECU - Walbro 255 Pump - Power Enterprise 850cc injectors But my question is what to get next.... i am thinking since i have about 400 hp that i should start to make suspension mods but i would like to get the turbo xs boost controller, but if not i want to save up for the cusco zero 2E's with the EDFC, what do you think i should do keep on engine mods or go with the supsension....??? |
What do you want the car to do? If you want it to handle better, then yes do more suspension stuff. If you want even more power, then hell, keep doing engine mods. Whatever floats your boat.
well thats the thing im not sure... i think i might just wait to get teh money for the coils
[QUOTE=NWassult] - APS Front Mount Intercooler
- APS FMIC Blow Off Valve - APS Cold Air Intake - APS 3.5 Turbo Back W/ Race Pipe - Hydra Standalone ECU - Walbro 255 Pump - Power Enterprise 850cc injectors [/QUOTE] You're missing 1 piece that will make these things shine... a turbo. Your fuel pump and the injector is way too overkill for you VF39 (stock turbo). Your flooding your engine for nothing. Those parts you have are common for having an upgraded turbo. Check out Deadbolt - [url]http://www.boostplanet.com/[/url] they have good set of turbos that will definitely put a grin on your face!!! |
i couldnt really find much on that website... i was thinking about saving up for the aps DR65 rotated turbo, cause that is about as big as it gets
My next buy would be a boost controller, this way you know you car is spiking your boost all the way. You don't want that it will cause more headaches then you want (especially since you have now voided your warrenty). After that I would buy a turbo because thats more power, and your car will run more efficient due to your huge injectors and front mount. But I would definatly consider buying suspension A.S.A.P. as well because it make a world of difference even though subarus already handle great, with that much power you want to make sure you have complete control over the car.
Just my 2 cents. |
thnx for the 2 cense i could use a couple grand though casue i think i am going to get the cusco zero 2E's, cusco 22mm front and rear sways, and cusco front ti strut with rear strut and triangle brace
| All times are GMT -7. The time now is 06:07 AM. |
