-   Subaru General (https://www.i-club.com/forums/subaru-general-30/)
-   -   i need help washington st (https://www.i-club.com/forums/subaru-general-30/i-need-help-washington-st-42405/)
michaelmorteo Dec 22, 2003 06:49 PM
i got the error codes
my warning light came on when i was going up a hill in seattle. the check engine light. i was woundering if anyone has one of those things that read error codes.if you can help i would be very happy.
thanks if you can help..:(
Keisatsu Dec 22, 2003 07:40 PM
the NW area forum may be a better place to ask.... ;)
michaelmorteo Dec 23, 2003 05:12 AM
well i just thought i know everyone comes through here why not put it in the biggest area! but im going there 2.:confused:
michaelmorteo Dec 23, 2003 02:59 PM
my error codes are
po182 low
po102 low
po113 high
does anyone know how to read this?
michaelmorteo Dec 23, 2003 03:04 PM
how do i get this damn check engine light to go off.:mad:
tide Dec 23, 2003 03:23 PM
You can reset the check engine light by disconnecting the negative cable from the battery and pressing on the brake for a minute or so. This will reset your whole computer and will cause gas mileage to be crappy while it relearns.
michaelmorteo Dec 23, 2003 03:25 PM
i got the check engine light to go off witht the code reader but it keeps coming back on.:mad:
tide Dec 23, 2003 03:26 PM
Well I'd take it to the dealer then. It's trying to tell you something's wrong. Any mods? It should still be under the 3 year warranty.
EZ Rider Dec 23, 2003 08:02 PM
Could be that gas cap thing. Next time you fill up make sure you tighten the cap till it clicks. If this is the problem, the light'll go off within a tank or two.
jun-wrx Dec 23, 2003 09:36 PM
[QUOTE][i]Originally posted by michaelmorteo [/i]
[B]my error codes are
po182 low
po102 low
po113 high
does anyone know how to read this? [/B][/QUOTE]
po182 low Fuel Temperature Sensor A Circuit Low Input
po102 low Mass or Volume Air Flow Circuit Low Input
po113 high Intake Air Temperature Circuit High Input
Hope this helps,
Jun
michaelmorteo Dec 24, 2003 08:10 AM
thanks. well the light shut off yesterday by itself. i guess the fuel air had to adjust itself. that why it was on but it off now and i've gained 3psi of boost. yeah!:banana:
