i need help washington st
my warning light came on when i was going up a hill in seattle. the check engine light. i was woundering if anyone has one of those things that read error codes.if you can help i would be very happy.
thanks if you can help..
You can reset the check engine light by disconnecting the negative cable from the battery and pressing on the brake for a minute or so. This will reset your whole computer and will cause gas mileage to be crappy while it relearns.
Originally posted by michaelmorteo
my error codes are
po182 low
po102 low
po113 high
does anyone know how to read this?
my error codes are
po182 low
po102 low
po113 high
po182 low Fuel Temperature Sensor A Circuit Low Input
po102 low Mass or Volume Air Flow Circuit Low Input
po113 high Intake Air Temperature Circuit High Input
Hope this helps,
Jun
americanmcss
Jul 21, 2011 09:09 PM
