Engine jerking at start up
I own an Impreza 2.5TS 2002
Motor is jerking at start up. The problem is intermittent and become apparent when I start it in the morning after or during a rainy day. At the beginning I thought that the clutch was causing the problem because it jerks only at first gear friction point & usually disappears when engine gets warmer. The dealer has replaced the clutch under warranty but the problem remains – it is getting worse since fall started. Now the problem is showing even at motor idle and last until motor gets warmer. Any advice? |
Broken motor mount?
[size=1][color=skyblue]-- 0==[color=blue]WW[/color]==0 "…axles of evil…" - george w. bush[/color][/size] |
