Need help- Do i Need an aftermarket stereo?
Car Info: 2004 JPB WRX
I just purchased a '04 WRX, has a 6 CD in dash player, I am looking to upgrade the speaker system with two 10" JL 10w3, and a Rockford Fosgate Punch 750S Amp (814 watts). Do I need to buy a new stereo to wire these in, or can I use the stock setup.
Tecnically u can use the stock set up, but you probably won't want to. Heres why; if you stay with your stock head unit, you will have to use amps that have a High level in-put on them, or get a high-to-low level adapter. What this does is take the amplified signal comming from your radio, (we tap in to the spkr wires to achieve this) and turns it into a low level signal that your amp can use to them re-amplify the signal. This greatly reduces your over-all sound quality. A decient after market deck will have RCA out puts. All amps have RCA in-puts.
A good deck will have 3 pairs of out-puts total: front, rear, and sub (somtiems called non-fading out put) When installed proplerly the seperate out puts will allow you to ajust the volume of the sub, with out changing your bass in your spkrs. With the stock set up, if you want more bump, turn up your bass, but then your spkrs will start distorting
Turn bass down, spkrs aren't distorting, but now the sub is not bumping.
Get an after-martket deck with 3 pre-outs, and you won't be dissapointed.
Mike @ Magnolia Audio Video
Awesome reply thanks, do you guys sell anything that would fit a 04 wrx, something for the above setup:
Two 10" JL 10w3, and a Rockford Fosgate Punch 750S Amp (814 watts)
I'd like something with MP3 cd capability.
I have an STi, threw the speakers from my 2003 in it and a Alpine deck. That made a HUGE difference. The stock Subie head unit blows. I highly reccomend a new head unit.
Nick
Nick
Any single or double din unit will fit into your 04. A nice head unit w/ mp3 and 3 pre outs will run you about 250 and up. I have free install w/ purchase of a deck and the parts will cost 35. (dash kit, and wire harness; we leave the stock harnes in tack.) And we will put your dash back to stock at any time free of charge.
Mike @ ROSEVILLE Magnolia
This really depends on how your final system is going to be. If you want an eleborate system such as new speakers, subs, a few amps and a lot tweaking capabilities. Then it is worth spending money on a new head unit and changer. (Remember you already have a tape deck and CD changer which means that if you want to buy an after market head unit you need at least a deck and a changer or an in-dash changer)
However, if you are just adding a pair of subs using amps driving them. You can buy amps with speaker level inputs and then you don't need to buy new head units and changers. Greatly simplifying the system and your hard earned cash.
I agree an aftermarket unit has alot of neat features that is great for building up a nice system. (Plus they look good and flashy to show off to friends..... and thieves) But if you just want a couple of subs then I don't see any reason to buy an aftermarket head unit for what you are asking.
I have pretty much the same question about this head unit. I have a MY04 wrx and I really like the look, functionality (6-disc in dash), and low profile of the stock unit. But there is no mid-frequency coverage. And the music I listen to actually suffers from overbearing bass beats, so I'd even give up some low freq.
Is the eq. on the head unit just not capable of producing better mid-level, or could I solve it with amp/speakers?
If I have to ditch the stock head, can anyone reccommend an aftermarket deck that has in-dash changer?
Thanks and sorry for piggybacking this thread.
You are getting to the heart of the matter. What is the purpose of the upgrade and what does the upgrade do?
If you want to fix the midrange-high then you should put you money into upgrading speakers driven by a nice amp. (i.e. separates with a real, properly designed x-over). Some quality amps have very good and adjustable x-overs on board that compliments stock head unit quite well.
It is true that if you want somthing very exotic / sound-off quality system then a head unit upgrade with the latest technology (e.g. I am excited to start seeing new head unit with digital time delays as in home theater) will be a great foundation. But in practice what you are after should be amps and speaker upgrades first. After all, if you still not happy then buy the head unit. But an indash aftermarket unit will be pricey.
Car Info: 2004 Impreza WRX
On ScoobyMods.com they have a thread with instructions on how to add RCA outputs to your stock radio. I guess you could try it if you really like the stock 6-disc but want good sound quality.
Just do a search over there, its been a while since ive seen that one so i dont know how effective it is.
i've upgraded everything on my system EXCEPT for the HU. as much as i'd like to throw in an eclipse in-dash dvd screen/player, i keep holding off for fear of theft. for what it is, the oem 6-disc changer is a great unit.
to answer your question, i went with a david navone LOC to convert the oem deck's high level output to low level RCA output.
Car Info: '03 Wrx w/vf-34, sti pinks,tbe, 2.5l cobb block
i had 4-5 1/2 kenwood door speakers, 2-10" punch z's with a 1200 watt amp and a cap off the stock deck and it sounds great. i have a seperate bass adjust for the subs so don't mess with the head unit.
juliannator13
Sep 10, 2012 09:25 AM
juliannator13
Sep 10, 2012 07:16 AM
buymeasti
Subaru OEM Parts For Sale
May 19, 2006 11:13 AM
