Rallied out WRX's 18g build
Old Mar 25, 2008 | 12:17 PM
rallied out wrx's Avatar
Car Info: 06 WRX, 04 FXT, 02 Forester L, 95 JDM LGT
Thumbs up Rallied out WRX's 18g build
ENGINE
Internals
-EJ257 block - blueprinted/port and polished
-heads - resurfaced
-CP 100mm Pistons, pins, rings
-ACL Bearings Race Series EJ257 Rod, Main
-gates racing timing belt
-Killer B high capacity oilpan pickup
Bolt-On
-EQ Smog blockoff plates
-TGV delete
-APS 70 mm Cold Air Intake
-Perrin IC hose kit (black)
-Perrin TMIC
-Perrin Turbo Inlet Hose
-Hallman Pro RX MBC
-Blouch 18g TD05 Turbocharger
-Titek catless DP
- with blacktrax ECS
-Borla hush exhaust
-Kartboy exhaust hangers
-Perrin light weight crank pulley
-custom carbon fiber pulley cover
-custom aluminum radiator shroud
-STI Oil Pump
-Walbro 255 fuel pump
-Deatschwerks 1000cc Top Feed Injectors
-NGK Spark Plug Iridium 1 Step Colder
-Subaru Group N HD Engine Mounts
coming soon
-oil catch can
-remove AC
-oil cooler
-catless UP
TRANSMISSION/DRIVETRAIN
-STi short shifter
-ACT clutch HD pressure plate, street disk
-ACT streetlight flywheel
-Type RA cryo treated gear set
-Kartboy shifter bushings front and rear
-Subaru Group N HD Transmission Mount
coming soon
-carbon fiber driveshaft
SUSPENSION
-Tien type Flex coilovers w/ EDFC
-Cusco rear sub-frame brace
-Whiteline 22mm rear sway bar
-Whiteline “big top mount” front strut tower bar
-Perrin end links
-Whiteline camber bolts
WHEELS AND BRAKES
-Rota DPT 17x9 white w/ Dunlop Direzza Z1 star spec 255/40r17 (street)
-Mach V Awesome Wheels 17x9 w/ Toyo r888 255/40r17 (track)
-BF Goodrich SS brake lines
-ATE blue break fluid
-Front STi Gold Brembo Calipers slotted Brembo disks w/Brembo RT TS20 Brake Pads
-Rear DBA 4000 Series T3 Slotted Rotors w/Ferodo DS2500 Pads
EXTERIOR
-STi spec c front lip
-STi rear air diffuser
-blue “I” impreza badge (front)
-Fastline Motorsports rally style mud flaps (off car now)
-JDM side visors
-painted (WRB) Seibon carbon fiber cw II hood
-Aero Catch Hood Pins (lockable)
-JDM spec c roof vent
-Lamin-x yellow headlight film
INTERIOR
-Samurai Sword Handle Shifter
-Defi gauge pod with Defi BF 60mm imperial boost, EGT, oil pressure gauges
-autospeed OEM style dead pedal
-JDM S203 hazard button
-Sparco harness bar
-Schroth Profi II FE ASM harness'
-KEY!S Racing deep steering wheel 330mm
-NRG short hub
-NRG quick disconnect
-Sabelt GT130 seats
coming soon
-oil temp gauge
MISC
-Viper alarm with remote start
-COBB access port v2
-Pro tune by Ed @ EQ Tunning
-DRL mod
-JDM air spencer (Squash)
-Halotron fire extinguisher
POWER NUMBERS
-EQ
266hp/316tq
BIG THANKS TO
PMAutoworks
EQ Tunning
Speed Element
GST Motorsports
Suby Dude
Mann Engineering
File Type: jpg
Last edited by rallied out wrx; Jun 5, 2019 at 11:28 AM. Reason: Updated list of mods
Old Mar 25, 2008 | 01:21 PM
thatguymike's Avatar
Car Info: 08 STI
Nice, 2nd pic looks like you can catch some air on those rollers
Old Mar 25, 2008 | 03:22 PM
KOSTI's Avatar
Car Info: Black On Black Wingless 05 STI
quick replace the "6" with a "4" on your garage..
ehhehe
Old Mar 25, 2008 | 05:09 PM
WagonTale's Avatar
Car Info: 06 Impreza
nice jason....wheres the pics of the white wheels
Old Mar 25, 2008 | 05:53 PM
ehhehe
lol. my old apartment number was 1320 (theres 1320 ft in a 1/4 mile)
believe it or not i never took pics of my car with those wheels on it.
Old Mar 25, 2008 | 10:21 PM
Paradox's Avatar
Car Info: me crazy when you ask "what suspension u on?"
Nice work done so far!
Old Mar 25, 2008 | 11:03 PM
NorCalBugEye's Avatar
Car Info: 413whp/461wtq
nice build list jason, glad to see the awesome numbers you put down!
Old Mar 25, 2008 | 11:15 PM
04caliwrx's Avatar
looks good man!
Old Mar 26, 2008 | 08:58 AM
sonic_yellow's Avatar
Car Info: 03' Subaru Impreza WRX - R.I.P.
Wow! Totally awesome build. Great progress so far since the first time I met you at El Camino/Lawrence Sbux a few years back haha. When are you going to put on your SVN's?
Old Mar 26, 2008 | 11:34 AM
svns will go on in May.
Old Mar 26, 2008 | 02:27 PM
A.V.E.'s Avatar
looking good Jason
such a coincidence that i spotted you and your GF when she got her wagon and now i spot you after getting a tune.
Old Mar 26, 2008 | 03:37 PM
Originally Posted by A.V.E.
looking good Jason
yeah, whats up with that?
Old Apr 6, 2008 | 08:13 PM
finally took some pics of the wheels
Old Apr 6, 2008 | 08:27 PM
pope 06 2.5i's Avatar
Car Info: o6 impreza.
sick wheels. sell me your stockers =]
Old Apr 6, 2008 | 08:45 PM
so steezy's Avatar
Car Info: *WiDe AnD LoW*
those wheels are awesome! did you get them powdercoated?
