Dash Problem
Probaly have heard this question a thousand times but i am having trouble removing all the dash parts to put my new head unit in my 05 STi, i removed the shifter part and then unscrewed the 2 screws holding the ac and radio area but now the ac vents are keeping the rest on and i dont want to rip at ai... does anyone have any diagrams or pics or step by step instructions???
I am having the same problem with my 06 STI. If anyone can help, it would be greatly appreciated!
Unscrew those two screws and pull it off. You may want to use something to slid in between to give you a little room to work with. Really it just takes some guts and a pretty good pull. Don't tug quickly because you might break something, but you do have to pull hard. It's scary the first time because you don't know whats's going on in there, but the only thing holding that piece in is the two screws and two clips at the top. Just pull harder. Good luck. Be careful not to scratch anything.
Thanks!
