2003 2.5XS Water Pump Replacement
Car Info: 2003 2.5XS Subaru Forester
Hey, I just purchased a 2003 2.5XS Forester with 93K on it. It has had the head gasket and timing belt replaced, but the water pump needs to replaced soon. Where can I find a new water pump cheap? And how do I go about replacing it?
try to find one online, is it DOHC?
96-99 2.5L Subaru Legacy Outback EJ25 DOHC Water Pump | eBay
How to replace it?
Remove radiator, crank pulley, timing belt covers, timing belt, then pump, 6 bolts on water pump, water hose on wp...voila! that's it
You have to mess with your timing so be VERY CAREFUL when you line up all the timing marks.
How to replace it?
JMeltzer4
Nov 19, 2012 03:15 PM
