-   How Tos / Installations (https://www.i-club.com/forums/how-tos-installations-192/)
-   -   Low coolant temp (https://www.i-club.com/forums/how-tos-installations-192/low-coolant-temp-255598/)
tsol Nov 18, 2013 11:51 AM
Low coolant temp
Hey guys I need some up diagnosing my car.
I have a '05 wrx that warms up fine. But once I get up to 70-80k my coolant gauge slowly drops.
I pulled a code with my A/P p0281 if I recall correctly which said coolant t-stat running low temp.
So changing out my t stat is what I would do first. Any suggestions on what t stat to get?? related issues?? Let me know what you guys think.
Thanks in advance
queeg9k Jan 15, 2014 06:58 AM
Street car? Factory thermostat.
the dude Feb 18, 2014 07:04 PM
pressure leak? hopefully not into your oil..how is the power?
the dude Feb 18, 2014 07:07 PM
or just a bad gauge but check and confirm the coolant level throughout the day and week...hope you figure it out.
wrxchase Feb 18, 2014 07:29 PM
i had the same issue a few months back. temp was fine then looked down and it said I was running cold after hard driving( never got a code). I had no leaks at all. turned out the thermostat had failed in the open position. I replaced it and the issue was corrected.
