Help!! Stupid jerking and cannot have full level gas.
-2004 STI 2.0 L Spec-C.
-VF 37 twin scroll turbo charger -Full Hks hi-power exhaust system (silent) -Catless down pipe -Bosche 275 fuel pump accompanied with a fuel compressor (set at 3.10) -K&N air intake (full system with induction and suction) -Blitz dumb valve (adjustable) -brimbo breaks, suspensions and etc. -Stock 2004 sti TMIC accompanied with an I/C Spray system (could be set on auto) -6 gears electric (DCCD) -Tuned with average boost of 1.4 bar (almost 22 psi) and timing of 24-26 (as far i believe) -Average of 305 whp -0-60 miles in 4.5 seconds average in night or cold weather. -Never filled with else than 95 octane. Hi all. I have re-tuned the car 6 months ago and right after tuning (remap) a cam-shaft sensor code popped (hesitation on second gear on 6-8 rpm). I got it replaced with a used sensor and re-plugged it to computer then no codes occurred. Now I am having similar problems which i doubt is linked to that one. Whenever I want to fill it with gas, always a quarter is missed (never at full level). I asked a mechanic friend of mine who said this is because of the "canister". I am also experiencing huge drop in fuel mileage. As well, i have noticed a gas smell, rarely, when i'm accelerating at the 6'th gear from low speed (Mph 60 onwards) I'm experiencing stupid hesitation as well on the third gear at Rpm 6. (which i believe is the camshaft sensor problem because code has flashed for a second and went off, same old problem, which i believe because the sensor i installed was used). Am i correct in my guess? Summary: -no full fuel level -gas smell when accelerating at 6'th gear (rarely) -Hesitation and jerking at third gear, also rarely, at rpm 6, with a fast code flashing. -vehicle's performance is never like before. I will really appreciate any kind of advice guys. Thanks |
[QUOTE=EK;3362824]-2004 STI 2.0 L Spec-C.
-VF 37 twin scroll turbo charger -Full Hks hi-power exhaust system (silent) -Catless down pipe -Bosche 275 fuel pump accompanied with a fuel compressor (set at 3.10) -K&N air intake (full system with induction and suction) -Blitz dumb valve (adjustable) -brimbo breaks, suspensions and etc. -Stock 2004 sti TMIC accompanied with an I/C Spray system (could be set on auto) -6 gears electric (DCCD) -Tuned with average boost of 1.4 bar (almost 22 psi) and timing of 24-26 (as far i believe) -Average of 305 whp -0-60 miles in 4.5 seconds average in night or cold weather. -Never filled with else than 95 octane. Hi all. I have re-tuned the car 6 months ago and right after tuning (remap) a cam-shaft sensor code popped (hesitation on second gear on 6-8 rpm). I got it replaced with a used sensor and re-plugged it to computer then no codes occurred. Now I am having similar problems which i doubt is linked to that one. Whenever I want to fill it with gas, always a quarter is missed (never at full level). I asked a mechanic friend of mine who said this is because of the "canister". I am also experiencing huge drop in fuel mileage. As well, i have noticed a gas smell, rarely, when i'm accelerating at the 6'th gear from low speed (Mph 60 onwards) I'm experiencing stupid hesitation as well on the third gear at Rpm 6. (which i believe is the camshaft sensor problem because code has flashed for a second and went off, same old problem, which i believe because the sensor i installed was used). Am i correct in my guess? Summary: -no full fuel level -gas smell when accelerating at 6'th gear (rarely) -Hesitation and jerking at third gear, also rarely, at rpm 6, with a fast code flashing. -vehicle's performance is never like before. I will really appreciate any kind of advice guys. Thanks[/QUOTE] Hey all, for any who had reviewed the thread, I just wanna confirm my thoughts were right as I replaced the cam shaft sensor and Canister and problems had gone. Thanks |
| All times are GMT -7. The time now is 05:06 AM. |
