-   Hawaii (https://www.i-club.com/forums/hawaii-43/)
-   -   Replacement Engine Belts (https://www.i-club.com/forums/hawaii-43/replacement-engine-belts-44945/)
iNfEk Jan 14, 2004 11:29 PM
I'm looking to replace my timing belt soon and know that PE makes (from what I've heard) a good replacement timing belt... My question does another company make replacement belts for the other belts for my car?
Jon
oldmansan Jan 14, 2004 11:47 PM
I thought
Subaru made a beefier one than stock.
San
iNfEk Jan 14, 2004 11:50 PM
really? which belts?
Jon
oldmansan Jan 15, 2004 12:09 AM
There is an
STI belt, but from what I read, it's a copy of the PE belt. Unless someone has something bad to say about the PE belt (haven't seen anything negative) I'd go with it.
San
IS2Scooby Jan 15, 2004 02:11 AM
How many miles on your engine? Why are you looking to replace you timing belt already!?!
__________________
[b][url=http://autoinsurances.wearecares.net]Best Car Insurance[/url] | [url=autoprotection.wearecares.net]Auto Protection Today[/url] | [url=trade-in.wearecares.net]FREE Trade-In Quote[/url][/b]
iNfEk Jan 15, 2004 10:32 AM
I got 40K+...
I'm really not looking to replace only the timing belt... I'm really looking to replace the other belts... I figure since I'll be messing with all the belts I should just do them all at once...
Jon
iNfEk Jan 15, 2004 07:55 PM
bump
markpaco Jan 15, 2004 08:35 PM
I'm not too familiar with Subarus specifically but timing belts are much more involved compared to accessory belts. This is because they are covered and have to be installed with everything (crank and 4 cams in this case) timed correctly. When I replace timing belts I usually replace the drive belts instead of the other way around.
iNfEk Jan 15, 2004 08:39 PM
[QUOTE][i]Originally posted by markpaco[/i]
[B] I'm not too familiar with Subarus specifically but timing belts are much more involved compared to accessory belts. This is because they are covered and have to be installed with everything (crank and 4 cams in this case) timed correctly. When I replace timing belts I usually replace the drive belts instead of the other way around. [/B][/QUOTE]
I know that if I'm going to be removing belts to get the timing belt I might as well replace them as well...
Jon
- I'm looking for aftermarket belts BESIDES the timing belt
markpaco Jan 15, 2004 08:51 PM
Oh ok. The way your message read implied to me that you were really looking to replace the other belts. Well regardless, what is the recommended time to replace your timing belt? I believe that my Subaru recommends it at like 100k which seems a bit long. My Integras were recommended at 60k and 90k. 40k is the shortest I've ever heard of.
iNfEk Jan 15, 2004 10:13 PM
[B] Oh ok. The way your message read implied to me that you were really looking to replace the other belts. Well regardless, what is the recommended time to replace your timing belt? I believe that my Subaru recommends it at like 100k which seems a bit long. My Integras were recommended at 60k and 90k. 40k is the shortest I've ever heard of. [/B][/QUOTE]
I think the recommended is 60K but since I drive it hard pretty often it might be time... Also I have a screatching noise when I reverse and turn my wheel (not all the way to lock) and another i-clubber said that it could be a bad belt...
Do you know of another manufacture that sells performance belts (stock size) for the 02 EJ20?
Jon
