head gasket problem?
Old Jun 6, 2012 | 07:55 PM
munkiebutt's Avatar
Car Info: 06 sti
Exclamation head gasket problem?
hi im new and own a 06 sti. Having problems i think its the head gasket. There white grayish smoke coming out the exhaust and white foam at the end of exhaust pipe. What could cause it, and whats a good shop to take it to.
engine mods:
perrin fmic
upgraded turbo (only know its a garret)
dealer said previous owner replaced a cylinder
pls help
thanks
Old Jun 7, 2012 | 01:18 AM
4080wrx's Avatar
you can also check your oil to see if it is contaminated with coolant.
Old Jun 7, 2012 | 07:56 AM
houdni's Avatar
Car Info: 06 STi
and you can also block test the cooling system for exhaust gases...
Old Jun 7, 2012 | 11:35 AM
munkiebutt's Avatar
Car Info: 06 sti
Oil looks okay from dip stick but gonna drain oil this weekend.
Another note there was smoke coming out from dip stick tube after running it.
As for block testing the coolant system I have no idea how to do that.
What's a good mechanic shop to take it to I don't have that much free time to work on it
Old Jun 7, 2012 | 12:20 PM
spinplay01's Avatar
From: Ice Palace...not the meth lab, the skating rink.
Car Info: 1995 dodge neon
I can pressure test your cooling system. Where are you located?
861 2328
Old Jun 7, 2012 | 06:13 PM
munkiebutt's Avatar
Car Info: 06 sti
At waipahu
Old Jun 7, 2012 | 09:23 PM
munkiebutt's Avatar
Car Info: 06 sti
I just let my car run didn't drive just let it idle for 10-20 mins no smoke from exhaust it seems to only happen when under load or long driving I don't know but I don't want to drive to find out cuz there was a lot of smoke coming out the exhaust people behind me couldn't see good
Old Jun 7, 2012 | 11:06 PM
PoCkEtRoCKEt74's Avatar
Car Info: 02 WRX
Is there a C.E.L. ? Whats the oil level at?
Old Jun 7, 2012 | 11:51 PM
houdni's Avatar
Car Info: 06 STi
coolant wont make the smoke linger....it dissipates after a few feet from the exhaust..or if its super bad will form some puddles at the end of your exhaust......
you are probably seeing bluish smoke.....your burning oil...
Old Jun 8, 2012 | 01:06 AM
munkiebutt's Avatar
Car Info: 06 sti
No c.e.l., oil level is good
Old Jun 8, 2012 | 01:08 AM
munkiebutt's Avatar
Car Info: 06 sti
There was white foamy stuff at end of exhaust pipe and grayish white smoke
Old Jun 8, 2012 | 02:22 AM
Hi_Sti's Avatar
Car Info: 04 Java Pearl
You should probably post some pictures on the "foamy" stuff and maybe a video of the smoke. Just a suggestion. Good luck.
Old Jun 8, 2012 | 03:50 AM
Xekh4's Avatar
Car Info: '04 STI
does it give off any kind of smell?
Old Jun 8, 2012 | 07:33 PM
munkiebutt's Avatar
Car Info: 06 sti
not any that i noticed
Old Jun 10, 2012 | 03:34 PM
munkiebutt's Avatar
Car Info: 06 sti
just drained the oil and looks normal nothing unusual.
can anyone think of what could be wrong?
