fuel pump controller
does anyone know where the fuel pump controller on a wrx is located i look online and it says the controller is located in the trunk behind the trunk trim can't find it can someone help me thanks. pic would help if possibly.
right side trunk (passenger side). peel back the liner and it will be on a metal panel that separates the rear quarter panel and trunk. the controller is mounted on the inside of that metal panel and will be facing the quarter panel and that is probably why you cannot see it. if i remember correctly it is mounted with one or two 10mm bolts.
see Dave I did learn something from you then just swapping motors
hahahaha good job Jess!!
nah its not too bad ive been driving for about 2 years without one on my swap,1st i was lazy then when i was acutally gonna do it i remembered i used my harness for it on 4080wrx car
drifter04
Nov 5, 2008 10:38 PM
dan2304k
Wanted
May 25, 2006 04:28 PM
ImprezaRSX
Feb 3, 2004 02:09 PM
JohnB
Jun 30, 2003 12:14 PM
