General Tech / How To's / Installations Technical discussions about the USDM 2008+ WRX and WRX STi.
Cut tube on blowoff valve?
Old Jun 12, 2010 | 10:00 PM
BenSti's Avatar
Car Info: 2008 Audi RS4 Ibis/Ti
I noticed that there was a cut tube on my blow-off valve, it looks like someone tapped off the main tube with a smaller one, but then never connected it. When the car is idling, there is a small amount of hot air blowing out of it. Is this normal? Can someone with a 08 STi check their car and see if it is set up like this?
Old Jun 12, 2010 | 10:16 PM
imHELLAslow's Avatar
Car Info: 20psi Daily!
that location of where it was T'd looks like it used to have a boost gauge of some sort. at least thats where mine is cut, and that tube leads into the cabin to my boost gauge. if you're not gonna hook up the boost gauge, remove the T and connect the two hoses with a barb fitting.
Old Jun 12, 2010 | 10:55 PM
BenSti's Avatar
Okay, that makes sense. It had a boost gauge before the dealer removed it. I am guessing that it should not just be venting to the air?
Old Jun 12, 2010 | 10:57 PM
KrAzYkld's Avatar
Car Info: 1998 M3, 2016 WRX
that is correct, that hose should not be venting into the air. it should be sealed. for a quick fix, you can find a screw that fits until you get a barb fitting to connect the hose back together (without the "T")
Old Jun 12, 2010 | 11:02 PM
BenSti's Avatar
Alright, I have a barb that will fit it. I will likely end up putting in a boost gauge anyways in the near future.
Old Jun 14, 2010 | 04:56 AM
Mulder's Avatar
Car Info: 02 WRX WRB
That's a manifold vacuum line. It should definitely be sealed, but also you should not be feeling hot air coming out. At idle there should be vacuum on that line so you should feel suction on it.
Old Jun 14, 2010 | 05:59 PM
BenSti's Avatar
I sealed the tube today, and it seems to have made a big difference to the performance of the car. I am not sure if it is just a placebo effect, but the car seems to pull harder at lower RPMs, and I have averaged 3mpg higher today than previous days.
Old Aug 26, 2010 | 05:02 PM
kwiksilverwrx's Avatar
Car Info: 2015 WRX Limited (sold 2009 WRX beast)
good call, why didnt the dealer keep the boost gauge on? thats stupid
ikes wrx
Nov 12, 2006 08:19 PM
K2Skier
Subaru OEM Parts For Sale
Apr 24, 2003 05:44 AM
subaruwrx511
Texas
Apr 13, 2003 09:22 PM
Daredevil
Mar 15, 2003 11:54 PM
BlackDubbaUREks
Feb 17, 2003 02:44 PM
