brake swap
gonna be swapping my brakes over to the 06-07 wrx 4/2 pot calipers. does anyone know if i need to change the master cyl at all? looked around on different forums and i can't find any info.
wasnt there a good reason Subaru went back to the floaters? I remember reading it somewhere.
But, if you are trying to upgrade the brake system...isn't there better ways of improving the system? For some odd reason, I think you shouldn't be going to just OEM pots unless they are from an STI, aftermarket brembos, ap racing, or stoptechs. I know what you mean about there not being to much info on brake swaps for MY08+, although I havent done any research myself, except drooling over these... [URL="http://www.streetbeatcustoms.com/Subaru/WRX/Brakes/Brembo-Brake-Systems/"]http://www.streetbeatcustoms.com/Subaru/WRX/Brakes/Brembo-Brake-Systems/[/URL] |
Have to agree, unless you have them sitting around in your garage, even then wouldn't bother. Just get some braided lines and some pads, alot cheaper..or an aftermarket bbk
ahh. i figured the 06-07 brakes would be a cheaper swap for 4/2pot calipers than the sti swap. but even then, the master cyl would probably need to be swapped as well yes? hmmm, research research
