2011 Imprza 2.5i automatic- some wrench sizes, maintenance
Engine Oil: 17mm or 11/16" socket
Front Differential oil: Torx V-70 hex-star driver
Rear Differential Oil: 10mm hex-Allen driver, and 3" extender for upper fill plug. Go easy, if you strip threads on plug the oil will slowly leak, new lower drain plug = $6 and new upper fill plug = $2. If you strip threads in holes on differential unit itself, you gotta buy that whole back cover piece for like $100 to restore. Both upper and lower plugs should fit in either hole, lower drain plug has magnet tho.
PCV valve: 3/4" Deep socket, and 6" extender. If you overtighten it don't go nuts trying to loosen back, the force you exert will probly break something else next to or beneath PCV valve.
Wish I had seen this post before I started replacing the rear diff fluid. Every guide I've seen (including a Youtube video on a 2009 2.5i) shows two plugs with 13mm square holes (which accepted a 1/2" drive breaker bar nicely). Looks like Subaru changed the rear diff cover design for 2011. Old plugs had pipe threads which called for thread sealant. New plugs are flanged, have straight threads and use a crush washer to seal. The new plugs appear identical to the design on Toyota trucks.
nslow_fast_out
May 18, 2008 01:22 PM
stevedood
Aug 8, 2005 05:53 PM
Eric MM
Jan 13, 2004 11:49 PM
