-   Engine/Power - EJ25T (STI and 2006+ WRX) (https://www.i-club.com/forums/engine-power-ej25t-sti-2006-wrx-90/)
-   -   Timing Belt Advice - Quote too high? (https://www.i-club.com/forums/engine-power-ej25t-sti-2006-wrx-90/timing-belt-advice-quote-too-high-265100/)
FL4T Jun 3, 2015 12:36 PM
Hey Guys,
I have an 06 STi with 52k miles. I don't have the mileage to change the timing belt, but I have the years. I was just quoted $700 at the local Subaru dealership. That seems incredibly high. What do they normally go for?
Thanks.
Funks Jun 3, 2015 01:10 PM
Contact Mert at RBMS Auto Care (Hayward)..
JourdanWithaU Jun 3, 2015 01:23 PM
What are they changing? I just paid $876.50 for my timing belt. I had other quotes at $870 and $950.
FL4T Jun 3, 2015 01:45 PM
[QUOTE=JourdanWithaU;3603087]What are they changing? I just paid $876.50 for my timing belt. I had other quotes at $870 and $950.[/QUOTE]
Whoa that's a lot. This is just a timing belt replacement.
JourdanWithaU Jun 3, 2015 01:59 PM
You want to just replace the belt and nothing else?
I had the Belts, pullys/tensioners, water pump, and coolant changed.
DabiDa Jun 3, 2015 07:07 PM
[QUOTE=JourdanWithaU;3603093]You want to just replace the belt and nothing else?
I had the Belts, pullys/tensioners, water pump, and coolant changed.[/QUOTE]
I know this a is dumb question just wanted to make that this price with parts correct? I know the water pump/belt kits run about $350. So that would make the labor cost about $500.
Javirex23 Jun 3, 2015 07:50 PM
You should do the full timing belt service and the water pump and other things around that. And do it ALL in OEM parts. Call some of our local shops and go with the best quote. RBMS, GST,LIC,AA Mmotorworks,FW motor sports just to name a few there are many other good shops. It's better to do it right the first time, than to risk a motor with so little mileage because of 1-200 dollars. My .02
FL4T Jun 3, 2015 09:26 PM
[QUOTE=Javirex23;3603140]You should do the full timing belt service and the water pump and other things around that. And do it ALL in OEM parts. Call some of our local shops and go with the best quote. RBMS, GST,LIC,AA Mmotorworks,FW motor sports just to name a few there are many other good shops. It's better to do it right the first time, than to risk a motor with so little mileage because of 1-200 dollars. My .02[/QUOTE]
Yea, that's true. Good point.
FL4T Jun 3, 2015 09:27 PM
To my knowledge its only the belt. He didn't mention anything else.
JourdanWithaU Jun 3, 2015 11:50 PM
[QUOTE=DabiDa;3603130]I know this a is dumb question just wanted to make that this price with parts correct? I know the water pump/belt kits run about $350. So that would make the labor cost about $500.[/QUOTE]
3 hours at $110, $330 for labor.
Timing Kit, $214.15
Water Pump, $125.95
Coolant, $51.32
AC Belt, $65.50
Alt/PS Belt, $17.95
Thermostat, $21.95
Taxes, $49.68
KingJeff Jul 26, 2015 07:04 PM
I paid $1200 for an 02 bugeye 5-6 years ago.
CatchMyDrift Jul 26, 2015 07:48 PM
That's crazy. I've done the timing belt, all the components and the water pump on any Subaru (wrx, STi, N/A EJ18/22/25) I've ever owned as well as past customer vehicle and it's never taken more than an hour and a half. The NA SOHC motors take about 45 minutes. Shops love to charge "book rate" instead of actual time.
