Looking for some help... I have a 2011 STi and my car is running lean at WOT.
I have a stage 2 91 Octane OTS map from Cobb via Accessport Stock intake (not for too much longer) Here are my mods: Cobb Catted Down Pipe Invidia Q300 exhaust Please Help! |
[QUOTE=rprasad1989;3614280]Looking for some help... I have a 2011 STi and my car is running lean at WOT.
I have a stage 2 91 Octane OTS map from Cobb via Accessport Stock intake (not for too much longer) Here are my mods: Cobb Catted Down Pipe Invidia Q300 exhaust Please Help![/QUOTE] If you are running lean at WOT, then first, i suggest you avoid running at WOT until you get it Pro-Tuned. Where are you located at anyways, maybe we can recommend some tuners to you. Second, if you are already running lean, then i highly recommend NOT putting on any intake mods, as they have the potential to make you run even "leaner". If your ECU hasn't already pulled timing due to knock, it likely will if you add any further mods. A blown engine isn't worth the risk right now IMO. YMMV |
| All times are GMT -7. The time now is 09:00 PM. |
