Same BOV?
Why would you need a different BOV for only a 1psi increase? I checked with a dealership today and it is the same part number as a WRX. I ran 15psi in my WRX and the BOV has no problems with it.
IF you were running more along the lines ofr 20psi then I can see the need for a different BOV.
It's adjustable. Between shifts when there's overpressure you'll hear it. Usually above 4000rpm. I think? I left the stock setting alone because the instructions were in Japanese. If anyone has advise on the right ammount of adjustment this it would be helpful to me. Thanks.
subiedave
15
Oct 20, 2005 07:56 AM
