-   Engine/Power - EJ25T (STI and 2006+ WRX) (https://www.i-club.com/forums/engine-power-ej25t-sti-2006-wrx-90/)
-   -   Only hitting 9psi boost? (https://www.i-club.com/forums/engine-power-ej25t-sti-2006-wrx-90/only-hitting-9psi-boost-265833/)
BradyBell33 Aug 12, 2015 01:52 PM
Hey guys i have owned my car for quite sometime and have always hit around 9psi boost. I never knew nothing of it until now, my target boost is 13.5 psi.
I have already done the soap and water leak test thing, and didn't notice any leaks. Do any of you know why i am not hitting my target boost? Like i said, i bought the car and it was hitting 9 psi. I have a CBE and CAI stage 1 91 octane map (Previous owner installed)
Please help:mad:
BradyBell33 Aug 12, 2015 02:27 PM
Update: i tried resetting the ECU, and the same issue is occurring... Im clueless on whats wrong.
Rev. Rob Large Aug 12, 2015 02:28 PM
That's about wastegate pressure. What kind of boost controller are you using? Try swapping BCS and see if it still does it.
BradyBell33 Aug 12, 2015 02:32 PM
Everything is stock except cat back excuse and intake. i don't have a spare bcs or a friend with one. is there a way to diagnose it without having a new one on hand already?
Rev. Rob Large Aug 12, 2015 03:27 PM
[QUOTE=BradyBell33;3611950]Everything is stock except cat back excuse and intake. i don't have a spare bcs or a friend with one. is there a way to diagnose it without having a new one on hand already?[/QUOTE]
Unplug the stock BCS, go romp on it and if nothing changes, your BCS is most likely dead.
BradyBell33 Aug 12, 2015 04:47 PM
[QUOTE=Rev. Rob Large;3611959]Unplug the stock BCS, go romp on it and if nothing changes, your BCS is most likely dead.[/QUOTE]
Romp on it? That won't hurt anything?
BradyBell33 Aug 12, 2015 08:25 PM
Update: I pulled off the bcs and checked it with the battery, it is clicking. I also sprayed some mas airflow cleaner through it. Put it all back on and it is acting the same still.
Any more ideas? I've read a little about restrictor pills? Or something like that. Don't really know what they are our what they do? Anyway. Open to ideas! Thanks
BradyBell33 Aug 12, 2015 10:00 PM
Update again.. I tried using a different tune. A HWG tune to see if it was the map I was running or something. And it is still reading the exact same psi.. I'm out of ideas😂
BradyBell33 Aug 18, 2015 08:21 AM
I found more help on another forum, but for throes of you with the same problem as me, it turned out to be my boost control solenoid, even though it passed tests it was faulty. I ordered a 3 port Cobb to replace it. Thanks for the help guys!
Rev. Rob Large Aug 18, 2015 09:12 AM
[QUOTE=BradyBell33;3612561]I found more help on another forum, but for throes of you with the same problem as me, it turned out to be my boost control solenoid, even though it passed tests it was faulty. I ordered a 3 port Cobb to replace it. Thanks for the help guys![/QUOTE]
Called it. :thumb:
Must have missed this thread when it was coming back around. Glad you got it sorted though.
