Only hitting 9psi boost?
Old Aug 12, 2015 | 01:52 PM
BradyBell33's Avatar
Car Info: 2006 Subaru Ipreza WRX
Hey guys i have owned my car for quite sometime and have always hit around 9psi boost. I never knew nothing of it until now, my target boost is 13.5 psi.
I have already done the soap and water leak test thing, and didn't notice any leaks. Do any of you know why i am not hitting my target boost? Like i said, i bought the car and it was hitting 9 psi. I have a CBE and CAI stage 1 91 octane map (Previous owner installed)
Please help
Old Aug 12, 2015 | 02:27 PM
Update: i tried resetting the ECU, and the same issue is occurring... Im clueless on whats wrong.
Old Aug 12, 2015 | 02:28 PM
Rev. Rob Large's Avatar
Call me Pebbles
Car Info: Moist
That's about wastegate pressure. What kind of boost controller are you using? Try swapping BCS and see if it still does it.
Old Aug 12, 2015 | 02:32 PM
Everything is stock except cat back excuse and intake. i don't have a spare bcs or a friend with one. is there a way to diagnose it without having a new one on hand already?
Old Aug 12, 2015 | 03:27 PM
Call me Pebbles
Car Info: Moist
Unplug the stock BCS, go romp on it and if nothing changes, your BCS is most likely dead.
Old Aug 12, 2015 | 04:47 PM
Romp on it? That won't hurt anything?
Old Aug 12, 2015 | 08:25 PM
Update: I pulled off the bcs and checked it with the battery, it is clicking. I also sprayed some mas airflow cleaner through it. Put it all back on and it is acting the same still.
Any more ideas? I've read a little about restrictor pills? Or something like that. Don't really know what they are our what they do? Anyway. Open to ideas! Thanks
Old Aug 12, 2015 | 10:00 PM
Update again.. I tried using a different tune. A HWG tune to see if it was the map I was running or something. And it is still reading the exact same psi.. I'm out of ideas😂
Old Aug 18, 2015 | 08:21 AM
I found more help on another forum, but for throes of you with the same problem as me, it turned out to be my boost control solenoid, even though it passed tests it was faulty. I ordered a 3 port Cobb to replace it. Thanks for the help guys!
Old Aug 18, 2015 | 09:12 AM
Call me Pebbles
Car Info: Moist
Called it.
Must have missed this thread when it was coming back around. Glad you got it sorted though.
Jimboi
20
Aug 1, 2013 08:51 PM
penguin051580
Apr 10, 2007 01:35 PM
wrxkid711
Jan 28, 2006 01:17 PM
t3ch9
14
Feb 2, 2005 10:14 PM
mista618
Aug 1, 2003 04:14 AM
